FP RED setups, recommendations, and advice
Old Oct 10, 2009 | 01:09 PM
  #361
tscompusa2's Avatar
Originally Posted by RockmanX
wtf lol i own lots or rids thats the website
96 geo storm
90 dodge caravan
2000 kia sportage
1997 Honda delsol
2000 hond civic
1996 eclipse hard top
1996 eclipse sypder
2008 Dodge Avenger
2008 Lancer GTS
2006 Nissian 350 Z
2003 Lancer Evolution
I almost bought a 09 ralliart and a 08 eclipse but did not like the room in the eclipse and my dealer was trying to rip me off completely on the ralliart as our dealer has only gotten ONE of them PERIOD we had 4 evos 3 were red all outsourced and 1 was MR edition 47k before taxes im not kidding lol was turned off so im putting lots of effort into the Z and evo man ill have some sick pics of the custom sound system i been building for the Z for you today when i get off work working on box for subs next week as well as lots of evo parts
LMAO.... no wonder you got to put payments on your evo build. wtf you need all those cars for at once? OMG 47k..... If I had that many cars + projects i dont think i could even afford to mod my evo lmao.......
Old Oct 12, 2009 | 05:57 PM
  #362
RockmanX's Avatar
nope all cars paid off except evo i just got it last year it would be paid off now if i was not modding i do break up payments on high dollar parts so if i get attempted scammed i did not commit much. All the cars are for various shows when im done i sell them and buy another one i try to buy one or two cars every year or so keep it fresh
Old Oct 29, 2009 | 01:53 AM
  #363
jeri534's Avatar
Im starting my FP Red build..i should have everything in a week or two, my goal is to get roughly 420hp, will this be pretty easy on my setup and how muhc boost should I be running to meet my goal?
Eventually Im going to want to run meth, but I want to put rod bolts/headstuds first..and maybe a set of S2s/springs
thanks
Evo IX
FP Red 80mm (Ported)
Ported/Coated Exhaust Manifold
Ported/Coated o2 Housing
ETS 3.5" FMIC
GSC S1
ETS LICP
FIC 850cc
Walbro 255
Going to be running 92oct
Old Oct 29, 2009 | 02:17 AM
  #364
yahu's Avatar
^I think you should be good for 420whp, probably around 26psi. It really depends on the car in this case, since they are mostly different. As some context, you will likely be on the same dyno I hit 430whp at 27psi, as did another person up here in the NW. Good luck!
Old Oct 29, 2009 | 03:51 AM
  #365
EVO8LTW's Avatar
BR 2.0 (drop-in rods/pistons at 15K miles)
BR stg 3 head w/BF 272s
BR ported FP-Red (64mm compressor housing)
BR Race FMIC with upper and lower piping
BR ported stock IM
BR 2-bend 3" intake pipe w/K&N cone filter
BR 65mm TB
BR ported stock exhaust manifold (Swain coated)
BR quiet TBE (bullet muffler and Magnaflow, coated DP)
FIC 1050cc injectors (mrfred scaling and latencies were dead-on)
DSM 1G BOV w/Dejon Tool leak stop kit
Walbro in-tank pump (single)
Helix 02 housing (Swain coated)
HKS DLI II
Blitz SBC id3 EBC
96530006 EDM ECU running tephra v5.1 and jcsbanks SD mods (formerly 96420008)
AEM 3.5 bar MAP sensor
GM AIT sensor
464 whp on the BR Dyno
Old Nov 12, 2009 | 12:16 AM
  #366
xcelr8's Avatar
Still putting the car back together after a blown motor. Hopefully up and running, tuned by spring;
BR stage 3 block 2.0
custom heads supertech dual springs/retainers/valves
comp cams 280/280
fp red 80mm/ported/25LBS wastegate
sparktech ignition
1200cc injectors
BR double pumper
halman boost controller
65mm TB
MAP rev3 intake mani
MAP O2 housing delete/dump downpipe
3''exhaust
hoosier DR's
Some other stuff.....Guesing my car weighs 2750-2800LBS.....cant wait to get it done
Old Nov 13, 2009 | 06:59 PM
  #367
churchja's Avatar
2.3L Rebuild w/FP Red Evo IX MR
Blew my motor a week ago coming back from SEMA to LA. Motor comes out on Monday. Going with a 2.3L rebuild. I will post pre-rebuild and post-build dyno results after the rebuild & tune for both E85 and 91oct+50/50.
Here's a list of my current mods:
My current mods include:
FP Green ported turbo w/FP 18 PSI actuator
RC1000 injectors
Agency Fuel Rail
FULL RACE exhaust manifold (tubular)
HKS 272 MIVEC cams
65mm Mil Spec TB (ported)
Sparco Intercooler
Supertech Springs & Retainers
Horsepower Freaks LICP
UICP
AEM meth kit
ECU load boost control
HKS DLI II
TiTek O2 housing
Walbro Fuel Pump
Baker small battery w/modded AMS small battery kit
ARC Intake Box
Ingalls Stiffy Engine Torque Damper
Full exhaust w/test pipe
HKS Ti Carbon muffler
Buddy Club grounding kit
ACT HDSS Clutch w/ StreetLite Flywheel
DEFI gauges (EGT, Boost, Oil Pressure)
Labonte flow gauge (for meth)
AEM UEGO A/F gauge
GM boost solenoid
OMNI 4-bar map sensor (for logging)
Stock ECU (flash w/ alternative map switching functionality)
E85 & 91oct + 50/50 Meth/H2O tunes
NEW MOD SETUP:
FP Red 80mm inlet ported turbo w/FP 25 PSI actuator
FP Evo Oil Filter Housing Line Kit
FP Evo 3" Intake Pipe
2.3L Stroker Kit with Forged Pistons (Wiseco or Mahle) bored 0.20"
MAP ported and polished head w/ 1mm oversize valves
FIC Bluemax 1450cc injectors
MAP AFPR Install Kit with Fuelab Regulator
MAP External 02 Dump
MAP Crankcase Vacuum Kit
MAP Rev2 Intake Manifold (for 65mm TB)
Buschur Racing Double Pumper Fuel System w/Dual Fuel Feed Line Kit
GM AIT sensor bung and ECU wiring (for Speed Density ECU mod)
P2R Thermal Intake Manifold Gasket
TiAL Q Blow-off Valve
BLOX Racing Engine Roll Stopper
EGR blockoff plate w/EGR system disconnected
Agency Fuel Rail
HKS 272 MIVEC cams
Sparco Intercooler
UICP
AEM meth kit
Tephra/MrFred ECU gear-based PSI boost control
HKS DLI II
ARC Intake Box
AEM UEGO A/F gauge
GM boost solenoid
OMNI 4-bar map sensor (for logging/PSI controlled boost)
E85 & 91oct+50/50 meth/H2O tunes
Old Dec 13, 2009 | 12:49 AM
  #368
dastallion951's Avatar
well id post on here my car and i have this love hate relationship she spends a lot of my money on herself and i have none left haha...fp red pump gas (91 octane ftl) 385awhp and 355 tq 27 psi spike hold almost 24 with dejon tool
heres dynograph well dont mind 107* ambient temps in colton in mid summer i like it pulls good just needs a race map tune
http://i77.photobucket.com/albums/j7.../dynograph.jpg
Last edited by dastallion951; Dec 13, 2009 at 12:56 AM. Reason: tryin to post pic of dynograph
Old May 16, 2010 | 01:52 AM
  #369
nevo24's Avatar
FP red setup goals
I made 360/340 @25 psi on 91 **** gas with my green. I have made some upgrades since then. I bought a red, tubular exhaust manifold, mil spec ported IM, TB. Plus aquamist. Here is my mod list now:
Stock 2.0l
FP RED (80MM)
Aquamist HFS-5
Buschur Exhaust
PTE 1000cc Inj
Kelford 272's
3'5 FMIC
Tubular mani
mil spec ported IM/TB
Injen ICP
ARP headstuds
BC Springs/retainers
ebay o2
ACT HD clutch
I will be tuning this in Sept when i get back from iraq. It will be done on a mustang dyno in AZ.
I'm not sure what mixture to run with the aquamist, but I would like to be running around 30psi. My goal is to hit at least 450whp. Do you guys think this might be possible? Can anyone recommend any mods that I might be missing to optimize the red? Thanks guys!
Old May 16, 2010 | 02:54 AM
  #370
MR. EVO MR's Avatar
Why not raise the boost to at least 33psi, your running meth and should be no problem. You should hit 500
Stock 2.0l
FP RED (80MM)
Aquamist HFS-5
Buschur Exhaust
PTE 1000cc Inj
Kelford 272's
3'5 FMIC
Tubular mani
Injen ICP
ARP headstuds
ebay o2
ACT HD clutch
Old May 16, 2010 | 04:42 AM
  #371
RockmanX's Avatar
Stock 2.0l
FP RED (80MM)
Aquamist HFS-5
Buschur Exhaust
PTE 1000cc Inj
Kelford 272's
3'5 FMIC
Tubular mani
Injen ICP
ARP headstuds
ebay o2
ACT HD clutch
3" TBE
spring and retainer upgrade
Port your reds hotside please
you should hit it easy but maybe after thats done you need to think about built motor and porting the head.
Old May 16, 2010 | 08:02 AM
  #372
tatsuIX's Avatar
Stock 2.0l
FP RED (80MM)
Aquamist HFS-5
Buschur Exhaust
PTE 1000cc Inj
Kelford 272's
3'5 FMIC
Tubular mani
Injen ICP
ARP headstuds
ebay o2
ACT HD clutch
e85 guy here, get a double pumper, e85 tune and raise the boost. Your RED will love ya for it! oh and port the s*** out of everything!
too much work on that sprayer (imho)
Bushur exhaust? TBE, CBE or just muffler?
Old May 16, 2010 | 08:11 AM
  #373
MitsoKid's Avatar
2.3L JAM
Stock head with multi-angle valve job
HKS 264/264 cams
FP Red, standard housing
Megan Manifold
FP SS 02 housing
Custom 3" straight pipe
OEM I/C piping
ETS 3" I/C
Tomei BOV
Forge WG
Factory ECU
7,300RPM Redline.. 425whp/400ft-lbs. 93octane, no meth. I usually don't run over 400whp though, its not needed for my application
Plans for the future. GSC S2's, a real manifold, ETS I/C piping
Or a HTA35R, haha.. Only if I get bumped to TTU class though. Otherwise I may go back to the green or possible a stock turbo.
Old May 16, 2010 | 08:12 AM
  #374
nevo24's Avatar
I forgot to mention that it was a TBE. I have def considered E85, but there is only one station around to my understanding the red doesn't even come alive until 30PSI. So if I set it to 33 would that be safe on stock block? I have to be careful because this is my dd.
Old May 16, 2010 | 08:15 AM
  #375
MitsoKid's Avatar
haha not on 91 or 93.. trust me.. one good knock and I broke 2 pistons at 27psi. may have been the tune but it runs fine on 116 octane so I think it was the 93
