FP RED setups, recommendations, and advice
Old Aug 9, 2009 | 05:29 PM
  #301
Wick3d3vo9's Avatar
WHat TB would you guys recoomend with the red?/ 65mm ported?? or 75mm ported??
Old Aug 9, 2009 | 06:10 PM
  #302
MSP608's Avatar
I'm not in the market for one so I don't really feel like searching, but how available are Red's these days? Are there still long wait periods no matter where you try to get one?
Old Aug 9, 2009 | 06:12 PM
  #303
JKD's Avatar
JKD
I recieved mine last week. Took exactly 8 weeks to the day to get it.
Old Aug 9, 2009 | 07:33 PM
  #304
Brent kuz's Avatar
Ordered from MAPerformance took little over 2 weeks. They really helped me out.
Old Aug 9, 2009 | 09:24 PM
  #305
o-townFLA's Avatar
The Mil.Spec 65mm is great...! No drivability issues and is super responsive...
Old Aug 9, 2009 | 11:00 PM
  #306
EvoTio's Avatar
Originally Posted by Brent kuz
I am running SLX Denatured Alky.
Brent kuz, you might want to check out this thread: https://www.evolutionm.net/forums/wa...l-hfs-5-a.html
Old Aug 10, 2009 | 03:04 AM
  #307
yahu's Avatar
I think it is worth it to wait for some of the dealers to get one or two in stock and ****** them up. I know Al from Dynoflash has gotten them fairly regularly in the last few weeks, but I don't know if that just happens to be how it happened or an ongoing thing.
Old Aug 13, 2009 | 03:09 AM
  #308
billedoc's Avatar
i recommend the 65 mm tb
Old Aug 13, 2009 | 11:23 AM
  #309
BLKCarbonEVO's Avatar
^+1
Old Aug 14, 2009 | 10:29 AM
  #310
mantosride's Avatar
let me ask you this guys, my red is in the mail and will be here tuesday, i am doing 880's, and there breaded line kit, I have all the bolt ons, TBE, FMIC, LICP, 02 housing, boost controller, AEM wideband, my question is do i really need to do head studs, I dont plan in running major boost, and i only run on 93. everyone seems to have mixed thoughts, i just want to try to avoid problems down the road, and from what i hear doing head studs one by one is not a good idea.
any advise
Old Aug 14, 2009 | 03:26 PM
  #311
any advise
Yes, It is a good idea to get head studs. Both High boost and knock can cause your head to raise. You can knock pretty easy on 93 on low boost aswell as someone on high boost with meth. All it really takes is a bad tank of gas and a STI pulling up beside you. I also know a lot of people that have changed head studs one at a time and never had any problems. I myself am one of them. Head studs are not an expensive mod and in the long run can safe you lots of time and money. +1 I say get them. In the end it's your choice and you are the one that's going to have to decide! Good luck
Old Aug 18, 2009 | 11:48 AM
  #312
Wick3d3vo9's Avatar
What spark plugs are you guys running, I'm at 33k with the stock plugs. What do you guys suggest??
Old Aug 18, 2009 | 12:16 PM
  #313
syktek's Avatar
i was running a copper plug but i found the car runs best with the OEM plugs (for the IX)
Old Aug 18, 2009 | 12:40 PM
  #314
IDRINKV8'S's Avatar
I run denso irduim plugs a lilttle pricey but there great gapped to 22 on my red setup with meth if your not gonna run meth 26 should be fine,also one step colder is a wise choice..
Old Aug 18, 2009 | 01:18 PM
  #315
EvolvedGTI's Avatar
IKH24, one step colder gapped @22
