FP RED setups, recommendations, and advice
Old Jul 21, 2009 | 06:32 PM
  #256
o-townFLA's Avatar
I'll pick up my car this Saturday with the following added:
- FP Red w/ 80mm compressor housing
- Mil.Spec 65mm Throttle Body
- Mil.Spec ported turbo hot-side
- Mil.Spec r2 version Intake Manifold
- Mil.Spec ported Exhaust Manifold
- Mil.Spec ported Invidia o2 housing
- Gruppe-S 3-port solenoid
- Dual map switch for 91/100
- Brian Crower springs and titanium retainers
- Re-tuned for 91 and 100 octane...
Current Mod List...
-TUNING TECHNOLOGIES dyno tune
-MISHIMOTO radiator
-MISHIMOTO air diversion plate
-MISHIMOTO silicone radiator hoses
-MISHIMOTO slim fan
-MISHIMOTO thermostat
-AMSOIL fluids
-MIL.SPEC 100 cell catalyic conveter
-Cosworth 272 M2 camshafts
-ETS 3inch front mount intercooler
-ETS 2.5inch lower IC pipe
-Forge MBC
-AEM short-ram intake
-Megan 3inch TBE
-Walbro 255lph fuel pump
-Precision Turbo Engine 780cc fuel injectors
-ACT heavy duty clutch
-ACT Streetlite flywheel
-ARP head studs
-Road Race Engineering front motor mount
-42 draftdesigns water temp housing
-SUN Auto Hyper Grounding kit
-SUN Auto Hyper Voltage type MR
-HKS oil cap
current power
330/320 on 91
360/350 on 100
I'll update on Staurday...
Old Jul 24, 2009 | 05:42 AM
  #257
syktek's Avatar
FP Red 80mm
Buschur Ported TB
Buschur Ported IM
Buschur Ported EM
Buschur Ported O2
Buschur TBE
ETS 4" FMIC
ETS Intake
Perin Filter
FIC 1050cc Inj
GSC S2 cams
GSC Spring/Retainers
Walboro 255
Synapse BOV
MBC
Meth (60/40 mix)
Car made 445hp/400tq @ 32psi on a Dyno Dynamics dyno (stock ecu, stock block).
Old Jul 26, 2009 | 01:03 AM
  #258
evobros's Avatar
what type of gas r u runing make those #
Old Jul 27, 2009 | 09:34 PM
  #259
syktek's Avatar
93oct (with meth)
Old Jul 27, 2009 | 10:59 PM
  #260
tscompusa2's Avatar
Originally Posted by syktek
93oct (with meth)
good numbers. thats what im targeting for with E85.
Old Jul 31, 2009 | 06:09 PM
  #261
will05's Avatar
I have seen people run 880cc on pump, but i will have to agree if u use meth that might help u out i 780cc and also on stock turbo to but mine injector duity cycle is on 53%.. I am looking as well going to the fp red so we will see.. Let me know what eles u find out...
Old Aug 4, 2009 | 09:35 AM
  #262
Wick3d3vo9's Avatar
FP Red 80mm
Buschur Ported TB
Buschur Ported IM
Buschur Ported EM
Buschur Ported O2
Buschur TBE
ETS 4" FMIC
ETS Intake
Perin Filter
FIC 1050cc Inj
GSC S2 cams
Walboro 255
Synapse BOV
MBC
Meth (60/40 mix)
I was wondering what your boosting?? Also are you holding boost till redline??
Old Aug 4, 2009 | 12:13 PM
  #263
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
read my sig
Old Aug 4, 2009 | 05:42 PM
  #264
Wick3d3vo9's Avatar
If I were to tighten the wastegate spring a little bit so it stays closed longer would I be able to hold boost more??
Old Aug 4, 2009 | 06:25 PM
  #265
tscompusa2's Avatar
yes, but you should only tighten it if its prematurely blowing the flapper open.
Old Aug 4, 2009 | 06:35 PM
  #266
BLKCarbonEVO's Avatar
Are you running the 25psi wastegate? I'm running the 25psi on my stock IX turbo. Here is the comparison between the stock wastegate and the 25psi https://www.evolutionm.net/forums/7314465-post62.html
In order to get the correct preload on the wastegate we had to cut 3 threads off the arm so that the turn buckle would preload enough. I'm holding 24.5lbs at 7k on my stock turbo. You should be around 27-30lbs if you are running 35+lbs on the red. I believe there is someone on the forums that I saw running 37lbs spike tapper to 30lbs. Also the higher the spike the more boost you should be able to hold out the top. Just remember even though you may hold more boost out the top doesn't mean you will make more power. You need to watch the shaft speed because is you over spin the shaft you will plateau and start to loose power because you are destroying the efficiency of the turbo. Not to sure what the shaft speed is on the Red but the HTA Green i believe was 153k. Here is the post that Scott as FP made. I would talk to him about the Red if you want to know all the mathematical specs and limitations. https://www.evolutionm.net/forums/7352513-post21.html
Crank down your wastegate and it should help you hold more boost.
Old Aug 4, 2009 | 06:41 PM
  #267
That really depends on what boost levels you are trying to achive. The wastegate is designed to spike 25psi "theroreticaly". Meaning that it should open earlier than 25lbs to start bleeding boost.
On my car we cranked the turnbuckle all the way in and it didn't look that preloaded so we cut 3 threads off and turned the turnbuckle down a few more turns. With it fully preloaded (meaning 3 extra threads cut off) I was spiking 29lbs without a boost controler. Just food for thought.
great mod IMO
Old Aug 4, 2009 | 06:44 PM
  #268
tscompusa2's Avatar
Why cut when you can just add washers and shim it?
added: btw do you know the apexi n1 is restrictive as hell? It dips down
as low as 2" in diameter where the resonator is. I actually cut the resonator
in half before on the catback because an sos pad got clogged up in there and
to my surprise it was restrictive as hell. This was on a 2g dsm, but the evo
setup looks very similar in restriction.
Old Aug 4, 2009 | 06:52 PM
  #269
You don't want to push the turnbuckle out more. You want to turn in down more, towards the wastegate itself. The turnbuckle should be a ***** to get on the flapper!
Old Aug 4, 2009 | 06:55 PM
  #270
You are correct. I only have the N1 exhaust though. My 3in exhaust line is a custom bent straight through 3in w/o a cat or resonator.
