FP RED setups, recommendations, and advice
Old Apr 16, 2009 | 08:57 PM
  #211
Furley's Avatar
What kind of power would I see from Red with a Buschur head/2.0 bottom with supporting mods on E85? Anyone have this setup?
Old Apr 16, 2009 | 10:32 PM
  #212
Import Junky's Avatar
I had nothing but problems with that damn Oil Filter/Supply Line. I gave up all together and used the stock line. I finally got a pm from Forced Performance after I notified them of my problem but I just sat on it and never sorted it out with them. Kind of stupid since I spent the money on something I'm not using. I guess in the end I knew they weren't just going to let me send it back after it was already installed and refund me. If anyone is interested in buying one just shoot me a pm. I'll let it go very cheap.....just have to find a different crush washer I guess.
Old Apr 17, 2009 | 04:19 AM
  #213
EVO8LTW's Avatar
Was your problem getting the line to seal properly at the head?
Old Apr 17, 2009 | 05:46 AM
  #214
evosam726's Avatar
well wit my red im running 880 but my car is still in shop lol
Old Apr 17, 2009 | 10:29 AM
  #215
Wick3d3vo9's Avatar
So we need to take this apart on every oil change?? or every other??
Old Apr 17, 2009 | 10:47 AM
  #216
EVO8LTW's Avatar
Every one. There's no bypass, so the dirtier it gets the less oil pressure your turbo gets. It's not like a regular oil filter that maintains pressure when dirty.
Old Apr 17, 2009 | 03:59 PM
  #217
Wick3d3vo9's Avatar
also new crush washer as well???
Old Apr 17, 2009 | 07:13 PM
  #218
EVO8LTW's Avatar
Crush washers are only supposed to be used once.
Old Apr 20, 2009 | 07:44 PM
  #219
Wick3d3vo9's Avatar
question, could I just unscrew the red part, and leave the other bolt in the head alond with the screw that screws in to that?? then I may not need a crush washer right?
Old Apr 27, 2009 | 07:33 PM
  #220
Wick3d3vo9's Avatar
hey is anyone running a double pumper setup up with RED?? I have a 255 but was wondering if an upgrade is needed??
Old Apr 27, 2009 | 07:43 PM
  #221
ROGERV's Avatar
Im running a double pumper but Im on E85. You won't need it if you plan to run pump/race gas.
Old Apr 27, 2009 | 07:56 PM
  #222
Wick3d3vo9's Avatar
well I"m on meth, I dynoed at 474 whp and 470 wtq on a mustang dyno. At what HP level should you start considering the double pumper??
Old Apr 28, 2009 | 07:04 AM
  #223
ninekrevs's Avatar
600+whp if you are running pump gas/race gas.
Old Apr 28, 2009 | 06:02 PM
  #224
Wick3d3vo9's Avatar
Well I did my first oil change on the RED, The filter was fairly clean, I couldn't see anything or any debris in there at all. I went ahead an replaced the filter and two crush washers. Started the car and let it run for about 30 min. no leaks, hopefully it stays like that. It is a pain though to have to do it every oil change.
Old Apr 28, 2009 | 06:30 PM
  #225
EvolvedGTI's Avatar
Care to share which type washers and where you are getting them? You guys got me worried about my install. got a fresh one that i need to install when i get home next month.
