Air Filter Shootout Test - Results!
Old Dec 16, 2009 | 12:56 PM
  #421
scheides's Avatar
EvoM Moderator
^Heh yea photo copyright 2009 chris@perrin, all rights reserved, must pay 3 gumballs or one gobstopper if you have viewed this pic
Old Dec 16, 2009 | 01:00 PM
  #422
Kracka's Avatar
Originally Posted by PERRIN_Chris
Hey, where's the credit for the picture? If I knew you were going to post it on here, I would have taken the plastic off at least!
LOL You could have staged them better too by having the logos facing the camera!
Old Dec 16, 2009 | 02:03 PM
  #423
PERRIN_Chris's Avatar
Redo:
Old Dec 16, 2009 | 03:24 PM
  #424
Kracka's Avatar
Any chance you could get actual sq/in measurements of the filtering media?
Old Dec 16, 2009 | 11:09 PM
  #425
Kevin.'s Avatar
Better #'s with the new filter? How new is it? Is it a new part #?
Old Dec 17, 2009 | 06:57 AM
  #426
scheides's Avatar
EvoM Moderator
Here's what Chris sent me, and some *ROUGH* calculations based on them:
3.125 filter: 6.25" high 17" girth (radius=2.7") surface area: 106 (cyl) + 22.9(top) = 128sqin
4.5 filter: 6" high 20" girth (radius=3.2") surface area: 120 (cyl) + 32 (top) =152sqin
**EDIT** look at the pics, the filter media is more than .25" different in height. I'll see if I can get new measurements from perrin.
So the new filter has ~85% of the surface area of the old filter. However, in the real world, most of the air will end up being sucked through the tip and top section of the filter, as that is where most of the fresh air is being delivered. Since I have an undertray, tranny, piping, frame, etc on all the other sides of it, ultimately it is the more the filter media that will dictate flow and less total surface area (as long as they are mostly the same size).
It'd be cool to see any fluid dynamics tests that have been done on this, actually.
Which new filter, the one I put on yesterday? I/we don't run a shop, and don't own a dyno, so hopefully I get time to do a quick before/after next time I'm on one of our local awd dynos.
Old Dec 17, 2009 | 08:15 AM
  #427
I agree, air isn't being sucked through the filter equally, so the total surface area doesn't really make a difference. Plus our foam filters filter dirt so well, it doesn't matter anyway. If you guys have some time on your hands, you can read the benefits of our foam filters here: http://perrinperformance.com/pages/show/129
Old Dec 17, 2009 | 09:19 AM
  #428
VRSF Tiago's Avatar
"Oiled for your protection!
All our foam filters are oiled with special thick, oil that clings to the foams structure. This special oil is what makes our filter, filter! The oil is what stops the dirt from passing through the filter getting into your engine. The oil is what catches the tiny little particles that would normally pass through the open holes in a dry type filters. The only dry type filters you will find around our shop are OEM ones we have thrown away or our foam filters in the middle of being cleaned! Dry filters rely on the very very small openings (as seen in the pics above) to stop dirt. Then they rely on being cleaned very often to get rid of the dirt to keep it flowing freely. "
Taken directly from their website. All you guys that removed the oil from the filter, you're not doing it right.
Old Dec 17, 2009 | 10:08 AM
  #429
Kracka's Avatar
Removing all the oil from a foam filter is a very bad idea. All I recommend is to take a paper towel and wipe up any excess oil.
Old Dec 17, 2009 | 11:09 AM
  #430
D-VO's Avatar
So, it sounds like there's a variable of filter placement in the engine bay as well correct? For instance, my filter is furthur away from the engine, and has the factory ram air thing (can't remember the name) pointed at it. Therefore, making use of more surface area.
Old Dec 17, 2009 | 11:40 PM
  #431
Kevin.'s Avatar
Does leaving that plastic ducting even do anything?
Old Dec 18, 2009 | 07:57 AM
  #432
Kracka's Avatar
I think it does a little at least. Why? Because I always have little bugs on my air filter right where the ducting points at it
Old Dec 21, 2009 | 12:40 AM
  #433
fostytou's Avatar
EvoM Community Team
Originally Posted by apagan01
98% sure it doesn't
we have affiliations with INJEN, INJEN does carry our filters.
Sorry, I swear when I was looking at their pipe that I could clearly make out "AMSOIL" in the same location as mine. I'll edit my post...
That does look like an amsoil but check the top chrome ring of your filter, does it say amsoil?
And you got this from PPI? Just like the one listed here? http://www.paradigmperformance.net/p...vo/filter.html
The pipe is home-fab ghetto-fab. The filter is direct from AMSOIL
Old Dec 21, 2009 | 10:42 AM
  #434
D-VO's Avatar
I've seen it being used by a couple of manufacturers: http://www.motorworldhype.com/wp-con..._cf_intake.jpg
Old Dec 21, 2009 | 08:38 PM
  #435
Kevin.'s Avatar
Did you not see the email from Wayne at PPI about the filter being Vibrant?
