oil return line being a pita
Old Jan 29, 2009 | 12:17 PM
def1's Avatar
this damn line will not stop leaking. I have changed the gasket out and even added a silicon oil gasket thing and nothing will stop this leak. Its not even a small leak, it is a big leak and I dont know how to fix it. Has anyone ran into this issue? What did you do to solve it?
Old Jan 29, 2009 | 01:43 PM
JakeTheVIII's Avatar
I think they have a tendancy to leak because of oil seeping through the threads on the bolts. That's the only thing I can think of that would still leak after silicone gasket etc. I don't know how determined you are, but you can try using a small amount of silicone gasket maker on the actual bolts themselves (the threads).
Old Jan 29, 2009 | 02:10 PM
def1's Avatar
ill give that a try. Its just so annoying having to get under the car, take the downpipe off and remove the oil line so many times
Old Jan 29, 2009 | 02:28 PM
FathouseFab's Avatar
The washers that go on the bolts have orings in them. Check/repace yours with the proper hardware.
Fathouse
Old Jan 29, 2009 | 04:08 PM
althemean's Avatar
yep
Old Jan 29, 2009 | 04:11 PM
fugiwara's Avatar
Pm benniboi (not sure the last couple #) but he just went through this problem, basically you need to apply some grey rtv.
Old Jan 29, 2009 | 04:17 PM
bboypuertoroc's Avatar
Veteran: Army
Fathouse
This.
Old Jan 29, 2009 | 04:20 PM
ETS Michael's Avatar
I had a simliar thing happen, but the drain line was cracked =X Good Luck!
Old Jan 29, 2009 | 04:36 PM
def1's Avatar
well if thats the case i have another one. it didnt looked cracked when i checked it.
Ill try the rtv first. and then Ill try replacing the washers.
thanks guys
Old Jan 30, 2009 | 08:31 AM
benniboi08's Avatar
yup..benniboi08 is me. lol, ive had this problem going for over 2 years now! finally got it sealed for good thanks to a very helpful tech guy Dino also on evom. Even the OEM (1 metal gasket and 1 paper gasket) did not do the trick. It was the rtv that sealed the deal..let me know if you have anymore problems.
Old Jan 30, 2009 | 09:10 AM
goosey2099's Avatar
If anyone is interested I have a new oem line for sale with oem bolts/washers/oil pan gasket.
Old Jan 30, 2009 | 09:14 AM
migs647's Avatar
How much? I may be interested.
Old Jan 30, 2009 | 09:03 PM
def1's Avatar
how did you drive with it like that for 2 years lol. Well I repalced the washers and added rtv to the bolts and a ****load of rtv to the top of the gasket. So Im crossing my fingers that this cures it. If not maybe Ill drive it to your house and have you fix it lol its seriously so frustrating.
e_kobz
13
Nov 17, 2015 09:24 AM
19DB794
27
Aug 15, 2013 07:17 PM
EvoRinga
Mar 12, 2012 07:39 PM
evo9ben
Jun 19, 2009 10:29 AM
levo2nr
12
May 25, 2006 05:49 AM
