Turbo problem?
Old Jan 31, 2009 | 11:18 AM
chase311's Avatar
Turbo problem?
Hey everyone, I'm not sure what the problem is here.. When driving my evom starting in 1st gear it will drive normally until aroun 3000rpm and suddenly there is a violent surge of power until around 4500rpm then suddenly it will drop 1000rpm then pick back up again even when I hold my foot into it. It repeats this in every gear. Even when cruising on the freeway in 5th at 80mph, put the gas to the floor, it will gain about 1500rpm before it drops 1000 and then picks back up. No matter what the enine is feeling way more erratic than usual. 06 Evo IX GSR, stock engine, no mods. Im thinkin about taking it to Mitsu....Any ideas?
Old Jan 31, 2009 | 04:46 PM
huevosrancheros's Avatar
shiet if its stock then take it to the stealership.
Old Jan 31, 2009 | 04:54 PM
0E3vobutt3r's Avatar
is the check engine light on? my car seems like it might be doing something similar.
Old Jan 31, 2009 | 05:00 PM
jlee's Avatar
it might be the clutch, im not quite sure.
when the boost hits around 3k or 3.5k the clutch slips and then it catches itself.
Old Jan 31, 2009 | 05:28 PM
gsrboi80's Avatar
Might be the clutch man
Old Jan 31, 2009 | 05:30 PM
wevo1985's Avatar
that sounds like a slipping clutch.
Old Jan 31, 2009 | 06:05 PM
chase311's Avatar
No check engine light. It doesn't do it at exactly 3k rpm. But, It always does it a second or 2 after you lay into the throttle. I was maybe thinking clutch as well, though I'm not sure. Timing perhaps?
Old Jan 31, 2009 | 06:16 PM
jmelocik's Avatar
CLUTCH MAN CLUTCH!!!!
Josh
Old Jan 31, 2009 | 06:37 PM
evokid511's Avatar
clutch
Old Jan 31, 2009 | 06:44 PM
chase311's Avatar
So here's my next question: does Mitsu warranty the clutch? 43700 miles.
Old Feb 1, 2009 | 05:03 AM
JKD's Avatar
JKD
Definitely clutch man. And no, no warranty with that many miles.
Old Feb 1, 2009 | 05:26 AM
JakeTheVIII's Avatar
It sounds like the clutch. I think they warranty them for 12,000mi. Now you see why!
Old Feb 1, 2009 | 11:36 AM
chase311's Avatar
Thanks for all the responses. Looks like I'll be swapping the clutch.
b0yw0nder
Jun 4, 2016 06:29 PM
Tibbar
Feb 1, 2014 07:50 AM
gallas
13
Jun 27, 2009 09:09 AM
crypto
Lancer Engine Tech
107
Nov 15, 2007 02:47 PM
titaniumkingpin
Nov 9, 2004 12:28 AM
