Whistling noise when car is driving!
Old Feb 7, 2009 | 06:51 AM
fastsrt4u's Avatar
Unhappy
Originally Posted by fastsrt4u
I just changed my clutch two days ago, and now i got my check engine light on.. I checked to see what code it was it is P0403. After doing some research i find out that a hose is pinched or the EGR valve is cracked etc.
I want to know does this make sense the reason for my car to be throwing this code and making this whistling sound is because it has something to do with this valve?
What do I need to do to fix this issue?
Thanks
Ok So I worked on the car yesterday, trying to figure out the whistling sound! i did a boost leak test and found out that a gasket that is between the pipe goes down from the turbo to the I C pipe, went bad. So I replaced it.... good no more whistling sound.... Re-did a boost leak test nothing is leaking air...
Went behind the T B to see the EGR valve to make sure no vaccum line popped off as the engine light is showing code P0403... but everything is intact... I reset the code turned on car drove it for a while, took it home shut it off, and then re-started Engine light back on, with the same code.... I dont know what else to do so please help me out!
Thanks
Old Feb 23, 2009 | 07:42 PM
LV///R's Avatar
Did you figure out what's going on?
I actually checked the 2 hoses that connect the the EGR valve, and they are both fine. The three that are on the EGR Solenoid are fine as well. I've checked over and over! I even took the EGR valve off and soaked it in some degreaser and hot water...put it back on...cleared the code and then it still came back on.
So,
1) Either the valve is stuck
2) The solenoid is not working
3) Or the intake manifold passages are full of carbon.
I'm going to have a shop take a look at it when I get my turbo/mani/02 housing installed...
Temujin
Apr 20, 2016 05:05 AM
Little G
Jan 31, 2010 08:03 PM
dambikeracer
Aug 8, 2009 02:56 AM
Xearo
10
May 9, 2009 01:41 PM
