Tomei Full Turbo Kit Install........
Old Mar 21, 2009 | 06:22 PM
  #121
i wanna go fast's Avatar
i didn't get a ride yet! how did my brother get a ride when i installed this damn beautiful thing?!
Old Mar 22, 2009 | 10:17 PM
  #122
fugiwara's Avatar
when are you gonna get this thing tuned? didn't you solve the problem already?
Old Mar 23, 2009 | 12:09 AM
  #123
evo ippo's Avatar
it wasnt my falt, your the one that was welding something
Old Mar 23, 2009 | 12:40 AM
  #124
evo ippo's Avatar
yeah i got the results let me put it all together and ill try to posted it up tonight
Old Mar 23, 2009 | 07:18 AM
  #125
midlifecrisis's Avatar
Right on! Hope things worked out for you.
Old Mar 23, 2009 | 09:11 AM
  #126
fugiwara's Avatar
Thanks!!!!! can't wait!!!!!
Old Mar 23, 2009 | 11:38 AM
  #127
evo ippo's Avatar
Ok here guys and girls the results:
Initial Impression: The Turbo Set-Up was constructed very nicely came with everything you need to install and no adjustment was needed it was a 100% bolt on.
Tuner : Naji at Looney Tune Racing ( He is the man, as he likes to say "the car is just vicious" LOL)
Psi: 91 Oct. set at 23psi tapering down to 20psi and 91 Oct. + Torco set at 27psi and tapering down to 23psi.
After Tune, Before Graph Thoughts: The car when compared to my Evo 9 Turbo has a mean pull in the mid range of the rpm, in 91 oct. and in 91 oct + Torco. Up in the higher rpm's it felt stronger but not as significant as like it was in the mid range. As for spool we hit Max boost at around 4k rpm at 23psi and 4218 rpm at 27psi. Here is the Data Log Lab graph, keep in mind that we estimated the car wait (the last time I actually corner balance the car was a year ago at Westend Alignments) so the numbers might not be exact but the Dyno Jet graph is coming soon.
First looking at the graph I was little disappointed the numbers where alittle lower then what I expected was expecting around 380ish with 91 and 420 on 91 + Torco. But keeping in mind that we wont know the exact comparison until the Dyno Jet Sheets. Car does feel really strong more then what the DLL showed but after analyzing the logs from evo scan and the zietronix wideband Naji and I came up with some conclusions
- Cams, The way the Turbo Looks on the Logs the Tomei Cams 270/270 will make the Turbo wake up and should become more of a beast.
- Boost setting, after analyzing the logs on the 91 oct will spike at 23psi at 4k rpm and slowly taper down to 20psi all the way to redline. 91 Oct. + Torco spike at 27psi at 4218 rpm and taper slowly down to 23psi. I know I can eliminate boost taper completely with my HKS EVC 6 w/ Easy writer software ( I Held 22psi all the way to redline with the Evo 9 Turbo) With Naji Logs on the car I can dissect where the boost start to taper and then adjust the offset accordingly to get it back to it set psi which in turn should give me more power in the mid - range and on the top end.
Conlusion: After I get the Boost setting sorted out i will be logging runs on the Dyno Jet, I am expecting the number should be alittle bit better and alittle bit more accurate. I love the car it has the mid range power that I love and should be able to pull me out of the tight corners like a supercharger.
Next Mods: - Ported Intake Manifold by *** It Motor sport
- Ported Throttle Body By *** It Motor sport
- Tomei 270/270 Cams
- Tomei Cam Gear
- Supertech Dual Valve Spring and Retainer
- ARP Headstud
Stayed Tuned...................
Old Mar 23, 2009 | 10:10 PM
  #128
fugiwara's Avatar
The DLL is similar to dynojet number right? I thought this turbo can make over 400hp dynojet on pump gas, at least that's what my tuner told me. It's a turbo between green and red.
Old Mar 23, 2009 | 10:34 PM
  #129
evo ippo's Avatar
well the DLL should be accurate if you put in all the correct info (Car weight with pasenger, wheel weight and size, etc.) in my opinion I rode in 400 whp evo and i think my car is up there in terms of power so that why we are turning to the dyno jet but also keep in mind my engine is completely stock too
Old Mar 23, 2009 | 10:43 PM
  #130
evo ippo's Avatar
This is a corrected DLL for the 91 Oct vs The 91 Oct with TOrco, the 91 oct made alittle more power then the previous graph
Old Mar 24, 2009 | 01:26 AM
  #131
addo's Avatar
What whp running a IX turbo & same boost on that dyno have you seen before? or would expect for comparison purpose?
Old Mar 24, 2009 | 07:37 AM
  #132
fugiwara's Avatar
I was told Tomei turbo is in between the green and red, therefore it should put down at least 400whp on dynojet
Old Mar 24, 2009 | 08:16 AM
  #133
Mr. Evo IX's Avatar
DLL reads very similar to a Mustang when it's setup properly. Razorlab did a comparison between DLL and his Mustang some time back and they were pretty close. An actual chassis dyno is more consistant because everything is controlled compared to being on the road where you have wind, grade, etc that can skew your numbers.
https://www.evolutionm.net/forums/ec...ml#post5814251
These are the first pump gas numbers with this turbo that I've seen.
What was corrected? You dont have correction turned on for either graph? Was the weight / gear ratio not correct for the 6 speed in your first graph?
Old Mar 24, 2009 | 09:58 AM
  #134
evo ippo's Avatar
I posted up my previous dyno jet graph and i made around 325whp at Tuning Tech Dyno at 23psi
Old Mar 24, 2009 | 09:59 AM
  #135
evo ippo's Avatar
same here +1
