My Battery Relocation
Old Aug 21, 2010 | 07:39 AM
  #31
joshesh's Avatar
So here are a couple pics from the finished product how my mini battery relocation to the trunk came out.
Things were very self explanatory, but ask questions if you want. I made the battery box and thread-cert into the trunk itself so the tie down if very secure.
Old Aug 21, 2010 | 09:32 AM
  #32
avo3vom's Avatar
Originally Posted by tweaker41
I just have to add to this thread that I've seen a lot of issues with relocating battery to trunk mainly from buying pre-fabbed kits with 4ga wire. Seems to be a lot of issued with battery melting or starting on fire. I did the relcation 10 years ago in my Ford Focus and I'm still running the same Optima red top in that car to this day with the battery in the trunk. I went to a welding shop and bought 00 arc welding wire and got a distribution block from a stereo shop. The system has worked flawless and my ground point in the trunk is just a rear seat bolt that was back there and I grinded off all the paint down to the steel. I'll do the same thing shortly in the Evo and will use minimum 1gauge welding wire which you can get in some of the summit racing kits and then probably a 200amp breaker.
Yes. definatly wouldn't use any thing less 1 gauge cable. I'm using a 150 amp breaker, not enough? 16 months no problems.
Old Aug 21, 2010 | 09:33 AM
  #33
kikiturbo's Avatar
here is mine.. full size Optima battery .. Used the spare wheel thread to ground... When covered, the boot floor is just about flat..
Old Aug 21, 2010 | 09:47 AM
  #34
avo3vom's Avatar
Now that is freakin sweet, that may be my new set up when I need a new battery ( still on stock one). Is that a locking strap holding it down? Fire extinguisher good idea for everyone. I have one stashed there to.
Old Aug 21, 2010 | 10:00 AM
  #35
usacchamp's Avatar
Wow nice work
Old Aug 21, 2010 | 06:21 PM
  #36
SME's Avatar
SME
Originally Posted by TommiM
A heads up to anyone who has or is thinking about relocating the battery to the trunk. I discovered the hard way that there are not very many good ground poiints for the battery. I had one that worked fine then a week later randomly had a no start issue ( I posted a thread on here for it). I used some threaded holes on the trunk sides, and while it may work for some for a while, its not the best. Make sure you at least scrape the paint to get a better contact. The best ground I have found imo is the spare tire 17mm bolt hole. Its not the prettiest place to mount your ground to, but from looking around back there during my install it is the best place, imo. Just thought I would throw this out there if any trunk mounted battery guys start having issues.
Grounded mine on one of the bolts for the rear strut. Heading into my fourth year of having it mounted in the trunk and she has started up every time
Old Aug 22, 2010 | 04:58 PM
  #37
TommiM's Avatar
I pretty much did my relocation like this how to.
https://www.evolutionm.net/forums/ev...-kit-evo8.html
I used a 2 gauge wire, which will work fine unless you plan on having an aftermarket sound system. 2 gauge is the smallest I would go. 00 gauge seems like a bit overkill though. Keep in mind your using ~5-7 ft of cable max. here is my trunk setup:
Old Aug 23, 2010 | 09:03 AM
  #38
avo3vom's Avatar
I scraped paint and grounded here, since I have the stock battery I used the spare bolt hole for the vent tube.My Battery Relocation-fire-exsting-001.jpg
Old Aug 23, 2010 | 09:21 PM
  #39
kikiturbo's Avatar
yes, the strap is holding it to the custom made bracket that is bolted to the spare wheel thread. If I could, I'd get a smaller optima battery, but those were not available over here.. Next thing to do is to pour some polyurethane foam in the trunk and replace these styrofoam pieces I put in..
Old Aug 24, 2010 | 12:40 AM
  #40
motoxxx55's Avatar
Here is how mine is done. Just a simple plywood & carpeted base & using back the stock tie down brackets...
The small sized battery has worked just fine for the past 3yrs...
Old Aug 24, 2010 | 12:48 AM
  #41
evonam07's Avatar
looks like RRE's kit..
Old Aug 24, 2010 | 12:49 AM
  #42
evonam07's Avatar
lol dayum seems like no1 carrys there spare tire
Old Sep 5, 2010 | 12:47 AM
  #43
bronto11588's Avatar
if your looking to do a relocation moroso makes all the stuff to NHRA specs you would need if you want still race as well this is one site that sells them www.lethalperformance.com
Old Sep 10, 2010 | 07:11 AM
  #44
SPANKED's Avatar
Good info, thanks everyone! I need to tackle this soon.
Old Sep 25, 2010 | 03:20 PM
  #45
wspy's Avatar
