Transfer Case Upgrade
Old Jun 21, 2009 | 06:17 PM
Werd's Avatar
So from what I've been told the stock transfer case on the evo is like glass, and if I'm going to be launching my car a lot I should upgrade the center diff. Is this the best and first step I should take to prep my car for hard launching?
Old Jun 21, 2009 | 08:13 PM
dambikeracer's Avatar
www.Sheptrans.com reinforce the tcase $1595.00. For those wanting more traction and improved reliability we take your transfer transfer case and install a Quaife Limited Slip Differential and reshim your transfer case. We feel the Quaife is the strongest available helical LSD for the EVO. On this upgrade we also upgrade the front differential cover bolts from 8mm to 10mm bolts and now add Heli-Coils to prevent side cover deflection and bolt pullout which allows a poor contact patch and failure of the ring and pinion. You may also build your five speed. Shep is the man!!!
Old Jun 22, 2009 | 07:18 AM
KazzEvo8's Avatar
Team Rip Engineering is a good option as well: http://www.teamrip.com/TRE_EVOLUTION..._SERVICES.html
Old Jun 22, 2009 | 08:45 PM
Werd's Avatar
Has anyone ever done this themselves? I'm pretty good with trannys and rears, never done a transfer case before but can't see how different it could be. But that sheptrans seems like a sick deal. For people who have had them work there transfer cases, how long did it take, from mailing it out to receiving it?
Old Jun 23, 2009 | 12:48 AM
dxbevo9's Avatar
honestly...i have had atleast 100 launches in my old evo which wasnt stock...i had an exedy twin clutch...and never ever broke or damaged the transfer case..
my advice to you..if it aint broken...dont fix it..however if it is...send it to Shep.
goodluck
Old Jun 23, 2009 | 01:07 AM
Raceghost's Avatar
Do any of these transfer case upgrades, well primarily with the Center Diff... Do they give the ability to adjust torque bias? Like if we wanted to give more torque to the rear, and less to the front. Get rid of the 50/50. My 8 doesnt have the ACD portion. I'd really like to set it to a 33/66 bias or close to that. Researched the CUSCO but it's limited on liturature.
Thanks in advance.
Old Jun 24, 2009 | 12:22 AM
Werd's Avatar
Thanks in advance.
Also curious about this. Anyone know anything about it?
Old Jun 24, 2009 | 07:45 AM
Zeus's Avatar
Center diff is in the tranny, not the x-fer case.
https://www.evolutionm.net/forums/ev...n-dummies.html
Old Jun 25, 2009 | 11:12 AM
insanechief's Avatar
I had mine built by jackstransmissions in Colorado. Great job and very happy.
Old Jun 25, 2009 | 12:19 PM
Balrok's Avatar
Thanks in advance.
Only two options I know of are the Cusco which I think is 35/65, and GSC's which is 40/60.
Kraise
Oct 30, 2015 02:35 PM
toyotabike
Feb 18, 2011 07:32 PM
daracer18
May 12, 2008 06:55 AM
Johnboy1065
19
Mar 27, 2007 02:32 AM
evo3matt
Feb 17, 2006 04:44 AM
