oh my CAT!
Old Jul 11, 2009 | 05:21 PM
BoostIt's Avatar
oh my CAT!
Question about puttin my cat back in temporarily for inspection. I have a full exhaust on the car and have to put my cat back in. Is that going to hurt anything or change anything being as though my cars been tuned with the test pipe in. Once I get my inspection done it'll come back out.
Old Jul 11, 2009 | 05:31 PM
FedEvo8's Avatar
It won't hurt anything, you'll just have the slower spool and boost will be about 4-5 lbs less than what you're tuned for. Just make sure your cat is heated up before inspection (if you have to run a sniffer test).
Old Jul 11, 2009 | 06:14 PM
MikesVIII's Avatar
i just had to do that to pass emissions. Took running my car on their machine 3 times but it finally passed.
Old Jul 11, 2009 | 06:23 PM
bbyevo8u's Avatar
^^ what machine?? i hope its an awd machine! was that with or without a cat?
Old Jul 11, 2009 | 10:20 PM
Oki Panoki's Avatar
its not gonna affect the car at all TECHNICALLY. you could safely run it, so dont worry. where i get inspected its strictly OBDII. so all that means is it is BASically the same thing as if your car was throwing a CEL because of the test pipe. the car knows that the rear o2 is not reading correctly and so throws an "not ready" (i believe its called) which the person who inspects it would then use to pass or fail you. but up in pa i think you can still pass the test with this ^. i believe we have 7 "checks". you have to have like 4 or 5 out of the seven to pass. so i think you can pass if your only issue is the rear o2. i dont consider myself an expert on this so i could just be talking out of my ***. this is just from what i have come to understand so dont rip my head off if im completely wrong
Old Jul 12, 2009 | 07:28 AM
Routybouty's Avatar
If it's just an OBII check and they don't use a sniffer then you can use the patches/ROM changes here on the forums to bypass the rear o2. Then you don't even need to stick your cat back on.
Old Jul 12, 2009 | 07:43 AM
FedEvo8's Avatar
Also, if you have an OBDII scanner, make sure that you have no CEL codes. If you do clear them, drive about 70 miles to reset the drive cycle.
Old Jul 12, 2009 | 05:50 PM
bogie432's Avatar
i had to pass inspection, with a "cat below eff" code. Just goto auto zone and get something called an spark plug defouler. Drill a 1/2" hole into one of them. Screw them together and put on ur rear o2 sensor. Search it up, theres a bunch of threads about it.
Old Jul 12, 2009 | 06:18 PM
slowr_evo's Avatar
x2^
jk_evo8
Northeast Region
Apr 13, 2016 05:38 AM
Sheasta
Jul 8, 2015 05:42 AM
Ironhide93
Jun 16, 2014 09:44 AM
jym89709
Oct 25, 2011 12:09 AM
ev0lution9
Northeast Region
Mar 17, 2009 04:24 PM
