clutch makes a sqeaky sound when down shifting.
Old Aug 19, 2009 | 12:17 AM
M_lizar's Avatar
I"m using royal purple. All the mounts are good. I know there is something up with my clutch cause it won't go into gear.
Old Aug 19, 2009 | 12:20 AM
tscompusa2's Avatar
royal purple sucks, use amsoil or penzoil syncromesh. If its not going in gear its the clutch master cylinder rod thats located right behind the clutch pedal. Read this thread: https://www.evolutionm.net/forums/ev...djustment.html
also check for oil down there also, the cylinder could have **** the bed, you never know. if that doesn't fix it then bleed the system.
Old Aug 19, 2009 | 03:46 AM
M_lizar's Avatar
Thanks I'll give that a shot when I get off of work.
Old Aug 19, 2009 | 03:49 AM
evoIXcencal83's Avatar
throw out bearing
Old Aug 19, 2009 | 08:10 AM
tscompusa2's Avatar
Originally Posted by evoIXcencal83
throw out bearing
if it was the throw out bearing, it wouldn't be disengaging the clutch. I highly doubt his TOB is bad or disconnected from the wedge collar by reading his posts on here. Don't scare him.
Old Aug 19, 2009 | 09:05 PM
M_lizar's Avatar
Ok so I adjusted my pedal and that didn't work.
Oziel
Dec 1, 2012 07:42 PM
Don Q
Feb 18, 2011 12:26 PM
eXtreme-Speed
Oct 23, 2009 12:39 PM
RotorGlowRA82
Mitsubishi TC-SST Discussion
Apr 30, 2009 09:26 AM
Dammit Cubs
May 29, 2008 09:09 PM
