Ways to hold boost at higher rpms
Old Oct 2, 2009 | 04:17 AM
  #61
Fast_Freddie's Avatar
Veteran: Navy
Here is a post from my buddy running an FP 25psi actuator on a IX turbo with cams and meth... he spiked 35 and still tapered to 24 at redline...
https://www.evolutionm.net/forums/7314465-post62.html
Old Oct 2, 2009 | 07:33 AM
  #62
neonglh's Avatar
Originally Posted by sparky
Is this a stock, unbuttoned longblock with untouched head and stock cams?
The head has never been off of the car, so yes, the bottom end and head are untouched. As mentioned though, the car has a set of Kelford 272 cams and stronger springs w/ titanium retainers.
How extensive is the porting work on the hotside? Who ported it? How much wastegate spring pressure are you running and what WGA? Also, what DV/BOV setup do you have?
The exhaust manifold is ported, and gasket matched to the exhaust side, which is opened up a lot. It was ported by studderin, a very well known porter in the gtp / ls1 community. His work is simply amazing.
I am running the stock wastegate, with the stock spring pressure.
I run a Tial BOV on my Buschur piping.
--mark
Old Oct 2, 2009 | 07:34 AM
  #63
neonglh's Avatar
Thanks!
boostn6262
24
Apr 30, 2012 08:31 AM
Gary@MellonRacing
Oct 28, 2011 06:03 PM
EpicEVO
Oct 2, 2008 09:28 AM
David Buschur
163
Oct 16, 2006 09:30 AM
David Buschur
49
Mar 13, 2006 09:47 AM
