ams Moustache Bar Eliminator
Old Oct 12, 2009 | 11:55 AM
  #106
revvin9k's Avatar
I have the AMS rear bar and I am running it with Whiteline bushings, no issues so far.
Old Oct 12, 2009 | 12:39 PM
  #107
inco9nito99's Avatar
Here are some pictures for those wondering: (I'm glad I was lucky enough to get the 'revised' one ).
Old:
New:
Old Oct 12, 2009 | 12:52 PM
  #108
EvoDan2004's Avatar
here is my setup. idk if anyone cares as this thread is full of junk but still. IMO this is properly setup
br side mounts. dont let crap move. i have yet to have issues nor do i see it in the future
Old Oct 12, 2009 | 01:44 PM
  #109
David Buschur's Avatar
Thanks for posting the pictures inco9nitto and evodan.
Old Oct 12, 2009 | 01:56 PM
  #110
revvin9k's Avatar
Old:
New:
Sorry to scare you Kunal, I saw this thread and thought the worst. Glad to see you/we are in the clear.
Old Oct 12, 2009 | 08:03 PM
  #111
MADBISH's Avatar
Originally Posted by EvoIXJDM
I just bought the ams moustache eliminator.... but after all this tread, maybe I will buy the buschur bar, grrrr.
I think that the the Buschur bar is the better replacement than the eliminator, and I dont want to worry about my diff and for the excesive vibration.
Thanks,
I might be doing the same as well.
Anyone with the ams eliminator kit feel like taking a video of the noise inside the car??
Old Oct 12, 2009 | 11:24 PM
  #112
DynoFlash's Avatar
Originally Posted by 9sec9
Amazing how PART of the truth is remembered. Filrst, my PARTIAL install was at my house, which you never saw. It was the drivers side I installed first, NO BIND. The ATTEMPT to install the passenger side was not completed (or the bolt installed for that matter) because it WOULDN'T EVEN LINE UP CORRECTLY. Your original mounts were not made correctly and as you know, Daniel told you that too. So your THEORY based on my conversation with you concerning why I wasn't using the side supports is in error. Maybe I could post some pics of the new one that you installed to prove that it also began to bend and show signs of fatigue. By the way, if the support wasn't failing, why did you redesign it? Other failures also occurred as you mentioned. Again, the PASSENGER SIDE is the side that didn't line up, so I un-installed the driver side and re-installed the OEM pieces. YOU NEVER SAW the install/attempted install of the supports since it occurred at my house. Nice try, but I think I have pics of the alignment issues too. I'm good at documenting things, I just don't always show all my cards.
Disppaointing to see a very wealthy guy like yourself going out of your way to try and smear Buschur's repuation. Seriously, its a shame.
Al
Old Oct 13, 2009 | 03:56 AM
  #113
huevosrancheros's Avatar
those pictures look gnarly.
Old Oct 13, 2009 | 08:13 AM
  #114
evodan2004, that rust makes me want to shed a tear......you drive that car in the winter?
Old Oct 13, 2009 | 08:14 AM
  #115
DynoFlash's Avatar
Its a shame that they are a total misrepresentation
If the two side supports were solid the diff could never tear out of the car in such a manner
As stated above the BR rear bar has three bolts to hold it to the diff
If you removed the one in the middle the diff would staill be very well attached by the other two bolts which go through the bar and into the diff
Obviously in the case of the pics above there was other installation errors going on
Al
Old Oct 13, 2009 | 09:26 AM
  #116
EvoooB's Avatar
I think we can settle all this by saying what has already been said... if you would like to put on the mustache bar and have it work correctly, you must also install the solid side diff supports. If you do anything differently, your on your own and dont ***** about it.
Old Oct 13, 2009 | 11:13 AM
  #117
revvin9k's Avatar
I have been running the AMS kit with Whitline bushings for at least 6 months. I have no issues. I planned on getting the BR side mounts after seeing them on inco9nito99s car when we installed them at my house.
Even if I did'nt, I don't forsee any issues with my set up the way it sits.
Old Oct 13, 2009 | 12:46 PM
  #118
94AWDcoupe's Avatar
Its not clear to us what you actually have. The ams kit comes with solid side mounts already. It sounds like you removed them and put on stock side mounts that have white line bushings in them? And now you want to get the burshur solid side mounts? makes no sense...
Old Oct 13, 2009 | 12:51 PM
  #119
Edited. I was wrong.
I asked AMS how their bushings work on the side diff support using their mustache bar eliminator. The bushings on the side diff supports are completely taken out and replaced with the supplied aluminum bushings. SO yes, it is confusing how the car would have whiteline bushings and the AMS kit.
Old Oct 13, 2009 | 01:01 PM
  #120
antilag_200's Avatar
Had my buschur bar and side supports on for almost 1.5 years, through michigan snow and all. Still holding up great.
