How much power will my setup make [Mega Merge]
Old Jan 25, 2012 | 02:48 PM
  #856
cbr600rx7's Avatar
LOL any one want to take a quicky at mine. See sig.
Old Feb 11, 2012 | 11:42 PM
  #857
9kredline's Avatar
Got enough parts lol
Old Feb 12, 2012 | 01:47 AM
  #858
stryfetew's Avatar
430-445whp
370 wtq
Just some wild 5am Sunday morning numbers
If the HKS you got is the one I'm thinking of though numbers should be about accurate.
Old Feb 25, 2012 | 11:10 AM
  #859
wilsonevo8's Avatar
Kelford 272, GSC beehive valve springs, APR head stud set, BR street FMIC, 3 port boost solenoid, synapse DV, ACT 3200 clutch, Bosch HighZ EV14 1600cc injectors, and walbro 255
E85 and stock 05 8 turbo.
Old Mar 1, 2012 | 09:54 PM
  #860
projektevo9's Avatar
Any shots?
2006 Evo Ix SSL
5Spd
1. Headstuds- L-19's
2. Mainstuds- ARP Main Studs
3. Main Bearings- ACL Race Main Bearings
4. Rod Bearings-ACL Race Rod Bearings
5. Balance Shaft Eliminator Kit- AMS Balance Shaft Eliminator
6. OEM Head Gasket
7. Springs & Retainers- GSC Beehive Springs W/ Titanium Retainers and Chromoly Spring Seats
8. Valves & Stems Seals- Supertech Standard Valves & Stem Seals
9. Pistons-Wiesco 1400HD's
10. Connecting Rods- Crower Steel Billet I-Beams
11. Cams -GSC S2 Cams
12. Cam Gear-HKS Adjustable Cam Gear
13. Fuel Pump-Buschur Racing Double Pumper
14. Fuel Injectors-Injector Dynamics 1000cc Injectors
15. Fuel Rail-AMS Fuel Rail
16. Fuel Pressure Regulator-Aeromotive A1000 FPR
17. Sparktech COP
18. Intake- Perrin Intake
19. Intake Manifold- AMS F1-I
20. Throttle Body- Boomba 75mm Throttle Body
21. FMIC-ETS 3.5 Front Mount & Piping
22. Exhaust Manifold- Shearer Fabrications V Band EXhaust Manifod
23. Exhaust-AMS TBE
24. o2 Housing- Shearer Fabrications V band O2 Housing
25. Turbo-Fp3586HTA
26. Transfer Case/Tranny- Built by John Shepard
27. Stage 5 DSS Rear Axles
28. Clutch Line-Ams Upper & Lower SS Clutch Line
29. Shifter Bushings-Bushur Racing Shifter Base & Under the Hood Bushings
30. Clutch-Exedy Twin Disk
31. Timing Belt-Cosworth Timing Belt
32. Tires-Dunlop Dirreza Radials 235 45 R17
33. Bov-Synapse DV
34. Wastegate-Tial 44mm V Band
35. Brake Lines- SS Brake Lines
36. Gauges-Aem Volts, Oil Temp & Wideband Gauges, Defi Boost, Oil Pressure, EGT
37. Radiator-Mishimoto Radiator
38. MBC-Hallman in car boost controller
39. Control Unit-Defi Control Unit
40. Battery-Carbon Fiber Braille 11.5lb Battery
41. Coil-overs-Bc Racing Adjustable Coil Overs
42. Short Throw Shifter
43. Vms Oil Catch Can
44. Stainless Drilled & Slotted Rotors
45. Carbon Fiber Wing, HIDs & Smoked Taillights
Take a shot on 93pump or E-85
Old Mar 2, 2012 | 11:40 AM
  #861
GG06MR's Avatar
^^^^ Seriously? I doubt anyone is going to give you feedback on potential power output when you're referencing shifter bushings and smoked taillights in your mod list. You're just wasting people's time at that point.
Old Mar 2, 2012 | 05:07 PM
  #862
Wow I just copied everything over my bad didn't notice that was on there
Old Mar 4, 2012 | 08:49 PM
  #863
SW20Mike's Avatar
Veteran: Air Force
03 Evo VIII
Evo IX turbo, Hallman MBC set at 22-23psi, ETS FMIC, Fujita intake, Fujita UICP/LICP, GSC S2 w/MAP beehive springs, Megan O2, Ebay 3" TBE,walboro 255, FIC 950cc injectors, ARP headstuds, Exedy Stg 1 clutch. I'm installing the IX turbo/Megan O2/CAMS/Springs and injectors this month, will get a etune reflash. On 91 octane and at over 4,000ft elevation, so I'm hoping for at least over 350ish, am I around the right mark?
Old Mar 6, 2012 | 12:58 AM
  #864
Terrible One's Avatar
you will need a fuel pump
Old Mar 6, 2012 | 06:13 AM
  #865
alex:)ix's Avatar
How much power I will make...
-stock turbo/block
-fp wastegate 18psi
-kelford 280
-arp head stud
-turbo xs ic piping
-1450cc fic
-mbc hallman
-sypnase bov
-walbro 255 fp
-downpipe with qtp catout
-invidia testpipe n unknow cat back
-act clutch 6 puck
Evo ix 5 speed on e85
Stock intercooler o2 housing n all the rest of the car
Old Mar 6, 2012 | 06:18 AM
  #866
SW20Mike's Avatar
Veteran: Air Force
Ive got a walboro 255, just forgot to put it on the list, doh
Old Mar 11, 2012 | 03:18 AM
  #867
GermanEvo's Avatar
Hello!
First post from a new member! This is Andre from Germany. Have an Evo 7 with forged rods and Evo8 Pistons. Stock intercooler (will be changed in the next weeks), Walbro fuelpump and at the moment Turbo from Evo 9 . Turboback 3" also installed.
Now its time for a bit more
I´m thinking about manifold from Toxicfab.
Kinugawa Turbo
Bigger injectors
full intercooler kit
cams from Kelford
I´m looking for 430hp to 450hp.
What do you think about that?
Cheers,
GermanEvo
Old Mar 14, 2012 | 09:11 PM
  #868
evoixman's Avatar
Hey guys,
I drive a evo ix completely stock right now. But the build is about to start. Just wondering what you guys think ill be making when I'm done.
1. 3 inch turbo back exhaust
2. Fp red ported and coated
3. Hks type S intercooler and piping
4. BC Valve springs and retainers
5. Gsc S2 cams + gears
6. Competition twin Plate clutch + flywheel
7. Custom exhaust mani coated
8. Hks mushroom filter
9. Arp l19 head studs
10. Walbro twin fuel pump setup
11. Dual map tune E85 & 98pump
12. 1350cc injectors ( for e85)
13. Fuel reg
Old Mar 15, 2012 | 08:35 PM
  #869
wilsonevo8's Avatar
3" TBE
Injen Intercooler pipeing and intake
Kelford 272
APR head stud set,
BR street FMIC,
synapse DV
walbro 255
??? Any guess's
Old Mar 15, 2012 | 09:40 PM
  #870
devildog08's Avatar
depends on a good tuner didnt know that had evo in pakistan world wide
