How much power will my setup make [Mega Merge]
Old Sep 26, 2013 | 06:42 AM
  #1051
Showbizz41's Avatar
Stock exhaust, FMIC, injectors, pump etc?
Old Sep 26, 2013 | 06:50 AM
  #1052
Raptord's Avatar
297.15625 whp.
Has it actually been tuned? Most important thing missing from your thread.
Old Sep 26, 2013 | 06:53 AM
  #1053
ReignMan24's Avatar
Is it a rebuilt 9 turbo or something else?
Old Sep 26, 2013 | 08:18 AM
  #1054
misterevo8's Avatar
some over 300 dynojet, lower on mustang.
Old Sep 26, 2013 | 10:29 AM
  #1055
xpawel1995's Avatar
Straight pipe 2.5 all the way ,stock injectors , might get the 255 pump , going to AMS dyno when I get time off my work maybe next month or the month after that.
Old Sep 26, 2013 | 10:30 AM
  #1056
xpawel1995's Avatar
Yaa stock evo 9 turbo rebuild faster spooling journals
Old Sep 26, 2013 | 10:38 AM
  #1057
boostedtres's Avatar
what are faster spooling journals and why the heck do you have new piston rings with a relatively stock car?
Did someone build the motor or was it grenaded or what? Something screams built then back to stock now needs tune desperately.
either way best of luck with the car man.
Old Sep 26, 2013 | 10:46 AM
  #1058
xpawel1995's Avatar
I replaced the stock piston rings to racing piston rings so they could hold more psi than the stock ones
Old Sep 26, 2013 | 10:52 AM
  #1059
JohnBradley's Avatar
Old Sep 26, 2013 | 11:05 AM
  #1060
ReignMan24's Avatar
So the 38lbs of boost I run on my stock bottom end w/ stock piston rings, isnt enough?
Old Sep 26, 2013 | 11:12 AM
  #1061
xpawel1995's Avatar
It is but I chacked my compression at first and it was low than I ported the head and put the new pistons rings in and j chacked the compression it was still lowe than I borrow a different compression tool and the compression was good so at the bigining my piston rings where good but my compression tool gauge was broken so I thought the rings are out .... what kind of mods do u have on ur evo
Old Sep 26, 2013 | 11:15 AM
  #1062
ReignMan24's Avatar
Gotcha. Ummm, pretty much every bolt on possible. Still rockin the stock bottom end and stock unported head.
Old Sep 26, 2013 | 11:26 AM
  #1063
xpawel1995's Avatar
How much whp did u pull out of 38psi boost
Old Sep 26, 2013 | 11:53 AM
  #1064
ReignMan24's Avatar
its in my sig man lol
Old Sep 26, 2013 | 04:42 PM
  #1065
Rondata.'s Avatar
Originally Posted by JohnBradley
classic. lmao
