Help with P1021 code please
Old Dec 15, 2009 | 03:18 PM
shunderwunder's Avatar
I'm geting a p1021 code (intake engine oil control valve circuit). I think this is MIVEC related but I'm nit sure what is causing it. I double checked the connector on the valve going to the MIVEC unit. Everything looks goot there. This is something that happened after I did my 2.3 install so I'm sure I fudged something up somehow. car seems to drive fine but I'm not driving it hard cause it isn't tuned yet. It's possible that the MIVEC isn't working & I just can't tell though. Any ideas would be greatly appreciated.
Old Dec 17, 2009 | 12:24 AM
9mr3vo's Avatar
p1021 code
Is there any loud noise on top of the engine when you hit the throttle abruptly? I'm having the same code with mine. I already replaced the oil feeder valve, but it is still the same. However, when I disconnect the wiring going to the valve, the noise goes away.
Old Dec 17, 2009 | 03:58 PM
No noise on mine.
Old Dec 30, 2009 | 01:53 PM
fbrs's Avatar
same thing here...valve replaced but cel still comes on everytime i start the engine...
what did you do guys about that?
could it be from low oil pressure in start up?
Old Dec 30, 2009 | 08:21 PM
No idea. Mines still doing it.
Old Dec 30, 2009 | 08:24 PM
fbrs's Avatar
what is your idle oil pressure?
i'm trying to figure this out before i open the engine for oil pump....
Old Dec 30, 2009 | 08:39 PM
1d10t's Avatar
What oil are you running?
Old Dec 30, 2009 | 08:41 PM
fbrs's Avatar
5-40 castrol
Old Apr 4, 2010 | 11:10 PM
biggie5252's Avatar
Any updates to this? I'm getting this problem now too.
Old Apr 5, 2010 | 05:09 AM
My issue was a loose wire to the MIVEC solenoid. It was from doing my motor swap so it was human error on my part & not a part failure or anything.
Old Apr 5, 2010 | 12:37 PM
1d10t's Avatar
Oh Andy. Do any tuning?
Old Apr 5, 2010 | 08:49 PM
Matt (TouringBubble) is working on setting up my car on stock ECU speed density. It takes a wile since we are remote tuning it.
Old Jun 14, 2013 | 09:30 PM
WikdEvo's Avatar
sorry to bump this back from teh dead but there aren't any current threads involving this code. I just did a intake mani, exh mani, fmic, turbo upgrade and egr delete all at once. I am getting this code now. I'm sure it's just a loose wire. Where is the mivec sensor located at? What does the sensor or connector that i'm checking look like? thanks
Old Aug 23, 2020 | 01:57 AM
cyberevo23's Avatar
5 Year Member
Unhappy
anyone solved this issue? i checked almost every possible solutions, new INT cam sensor, new solenoid, redid timing and still having the p1012 and p1021 fault code.
Sheasta
Feb 14, 2021 09:00 AM
chris4b11t
Mar 11, 2017 07:51 AM
selp
Feb 28, 2011 09:58 PM
criptballer
Jun 30, 2010 12:21 PM
jamie_v1
Apr 8, 2010 03:38 PM
