Rear Diff Options - Power Oversteer Found Here
Old Nov 18, 2011 | 07:16 AM
  #676
Kasaper's Avatar
There was a little noise at first, not very loud at all, you notice it more under 5mph, but now it sounds normal now, got 200miles on her and its fine!
Old Nov 18, 2011 | 11:11 AM
  #677
bayrider's Avatar
Nice! I can't wait to get mine done.
Old Nov 25, 2011 | 09:53 AM
  #678
kyoo's Avatar
ive actually still been really interested to hear from anyone using the carbonetics rear diff.. supposedly much better performance in terms of lock up, engagement, noise etc
Old Nov 30, 2011 | 08:57 AM
  #679
wjamyers's Avatar
I emailed TRE last night. Jon responded about an hour later. Said he's still moving shop and will not be ready until the end of Dec. I will wait patiently.
Old Nov 30, 2011 | 05:32 PM
  #680
hokiruu's Avatar
For what it's worth, what decided for me was: I call Shep, and he answers right away ever time. I called TRE, no answer. Sent TRE an email, and received a reply four months later. By then I had already swapped cores with Shep. Needless to say, I'm now enjoying my Shep 12 plate.
Old Nov 30, 2011 | 06:33 PM
  #681
TommiM's Avatar
True. If it wasnt for SpeedElement having a TRE diff in stock at the time I would have gone with something like a Carbonetic unit.
Old Nov 30, 2011 | 06:42 PM
  #682
kyoo's Avatar
I almost wish you had, I'm really curious to hear someone's reviews on the carbonetics, and see if it holds up to all the claims it makes.. Anyway I'm really satisfied with the Cusco
Old Dec 15, 2011 | 05:25 PM
  #683
TommiM's Avatar
http://www.amsperformance.com/cart/c...lsd-front.html
They make a 1.5 way front diff for acd evos. I read on here about non acd evos getting aftermarket front LSDs, but Im wondering if its any benefit to upgrade the front diff on acd evos? Oem is 1 way iirc, the carbonetics is a 1.5 way. Im thinking that might induce more understeer though.
Old Dec 15, 2011 | 05:41 PM
  #684
kyoo's Avatar
I heard it is - I remember a few years ago a lot of people were running qauife or wavetrac - typically 1-way in the front though. I'm sure all the diff parts compliment each other.
Old Dec 26, 2011 | 03:46 PM
  #685
kyoo's Avatar
bump - is the stock diff modified with the TRE a "torsen" clutch pack type diff?
Old Dec 28, 2011 | 09:33 AM
  #686
kyoo's Avatar
FYI just a mini update -
my Cusco didn't click or chatter.. it violently banged. swapped the amsoil svg gear 75w90 w gear lube to OEM diaqueen straight 90 gear lsd oil, and the thing doesn't make a peep anymore.
Old Dec 28, 2011 | 05:04 PM
  #687
TommiM's Avatar
Thats one reason Im interested in the Carbonetics diff. Using any other GL5 redline fluid my diff is quiet, although it does have better performance with the 'loud' fluid.
Old Dec 28, 2011 | 05:29 PM
  #688
kyoo's Avatar
definitely let me know if you decide to try that diff - i'm particularly interested in their claims of gradual lock up and stronger lock up due to the materials used. the cusco overcomes clutch type lock ups using some trick springs, don't know how others do it.
i'm definitely very satisfied with the oem diaqueen though, i wish i changed to it sooner. seems these diffs simply just really prefer the straight 90 stuff - i thought a better fluid would be better, but its not. not a peep anymore, and if it doesnt perform quite as well, that's fine, i had more lockup than i needed
Old Dec 28, 2011 | 05:40 PM
  #689
Montu's Avatar
so where are you guys getting the Redline 80w-140 NS from? all i see is standard 80-140 with friction modifiers for maximum lock up without caring about noise I want the NS correct?
currently using oem diaqueen in my tre max lock but want more lock up :-)
Old Dec 28, 2011 | 07:15 PM
  #690
TommiM's Avatar
When I was living out in your neck of the woods I was able to find at almost any napa auto parts store.. http://www.soloperformance.com/Red-L...NS_p_1181.html this is the stuff, I dont remember them having a 80w140 version of it though.
Out here where Im living at now seems like I will probably have to order it online.
