ACD Tuning Options - USDM CT9As, Read!
Old Sep 26, 2016 | 11:07 AM
  #481
MrAWD's Avatar
I wonder how this works when you have to go through the slalom! If I select TARMAC, sweepers are pretty nice and car rotation is really great. But, when I get into the slalom, rear end starts to jump around whenever I turn to the other direction. So, I end up chasing my tail through the whole section. Switching back to GRAVEL fixes that issue and I like the car better this way. Sweepers are a bit tighter, but you can still get around under throttle.
Now, if this FIX (I know it is not for EVO X) could fix both of these and kind merge its behavior, it would be special.
So, any idea how car behaves in slaloms with this?
Old Sep 26, 2016 | 11:27 AM
  #482
kaj's Avatar
kaj
Put the switch on your steering wheel. BOOM.
Old Sep 26, 2016 | 11:39 AM
  #483
kyoo's Avatar
i think it's a completely different issue here. the X behaves that way as the sayc is trying thinking when you engage a slalom that you want to turn that direction instead of dart in and out, so it's shuffling power side to side and all that madness.
we're opening up the center diff here so there's nothing on the drivetrain that's "trying" to do something. at the limit when you lose traction it will be probably be neutral, more depending on suspension setup and driving, but otherwise if the tires have grip it will just turn better.
that's as far as I can tell on my acd tune & slaloming. I had some looseness issues earlier but I think that was tires braking in and driving & shock set up. car just behaves as I want it to now. that's not to say it won't do a tank slapper in slaloms - it can and has, but that was more related to my driving.
as I still understand it, ACD tunes disable AYC function, so in that regard, it would probably stop your car from getting tank slappy in slaloms.
Old Sep 27, 2016 | 04:39 AM
  #484
tscompusa's Avatar
I had two customers with my ACD MAP perform at Sebring. Hopefully they review it.
Old Sep 27, 2016 | 06:16 AM
  #485
MrAWD's Avatar
Any idea when EVO X stuff will be ready?
Old Sep 27, 2016 | 12:35 PM
  #486
kaj's Avatar
kaj
Finally got a spare ECU. Now, to tune it before the next PCA event and, dare I hope,.....Super Lap Battle?!
If so, reviews will be forthcoming.
Old Sep 27, 2016 | 07:26 PM
  #487
tscompusa's Avatar
I'll ask the original maker of the 6 map program im using and see if we can do anything for the Evo X.
I will follow up with his response.
Old Sep 27, 2016 | 07:44 PM
  #488
kyoo's Avatar
whose?
Old Sep 27, 2016 | 08:09 PM
  #489
kaj's Avatar
kaj
Originally Posted by kyoo
whose?
Either sending to Tom or using a ROM from another ECU I have access to. Either way, I'm stoked.
Old Oct 12, 2016 | 02:22 PM
  #490
suby2evo's Avatar
Originally Posted by suby2evo
Hahaha exactly I saw Tom offer the 6 map for $100 and I ordered an acd ecu from ebay last night for $33 with free shipping. The second I get it I'm gonna ship it to him.
I will report back here with results.
current setup (which I love)
-365whp
-OEM size Hankook RS-3 on 8.5 wide RPF1's
-Ohlins DFV ( swift 8/9k springs)
-swift RSB (only 20% stiffer )
-whiteline RCK
Okay so I've had Tom's 6 map tune for about two weeks now.
Yes all I can say is yes! dollar for dollar I have not done a single mod in my 6 years of ownership that made such a significant difference for less than the price of 1 tire hahaha, if you are on the fence just do it please. There are no downsides if you are paranoid about pump pressures this program allows you to drive around on the stock settings too.
I love the way the car behaves it's almost like having a sport mode that actually makes a significant change to the way the car behaves, I do not find the oversteer overwhelming like others have said about acd reflashes. My only wish is I did it sooner for the price theres absolutely no reason to get this, Thanks Tom!!
Old Oct 12, 2016 | 02:38 PM
  #491
kyoo's Avatar
thanks for the input, and glad to hear you're all right from matthew!
any events upcoming to do some before and after between the aftermarket settings and stock Tarmac?
Old Oct 13, 2016 | 10:06 AM
  #492
Casey Robertson's Avatar
I'm just trying to help out. I'm only making $50 on that deal and doing all the work (bench flashing, etc). I have to share my profit with the person who originally gave me the 6 map system.
As I said before also, we can mix the maps with our maps with people that want both. I'm pretty certain our maps do the same thing as everybody else's though. There's only so much you can do to improve the car drastically.
Tom, best way to get in touch? I see ACD ECU's on eBay - I have a 2005 GSR. Thanks
Casey
Old Oct 13, 2016 | 11:00 AM
  #493
kaj's Avatar
kaj
Casey
+1 I PM'ed you back, Tom, regarding my paypal info for the invoice, but EvoM says it's unable to send you the message.
Let us know. Thanks!
@tscompusa
Old Oct 13, 2016 | 06:29 PM
  #494
aamoedo's Avatar
Has anyone confirmed if the acd units are vin specific? Or could I buy an eBay one and send it in?
Old Oct 13, 2016 | 11:15 PM
  #495
555R's Avatar
hey ts comp
have you made any new ACD maps since i pick up ACD mapping from you ?
I still have an extra ACD ECU i can send if there are new maps made...i pretty much run the number 1 map out of the 3 i got, i guess its the dry map.
let me know if there are any new mappings you have and pm info where to send and cost etc.
fyi
I've had the TSCOMP reflash i think two years now along with the restocked rear lsd and full urethane bushings, corner balance and coil over height adjustments.
the car is mad. the way every evo should be...i think an more aggressive lsd is the only next step i have.
