ACD Tuning Options - USDM CT9As, Read!
Old Jul 9, 2017 | 08:21 AM
  #541
kaj's Avatar
kaj
Originally Posted by kikiturbo
you can use the USDM VCU transfer case and leave the stock centre diff..
Pretty much what I've been considering.
Old Jul 9, 2017 | 03:33 PM
  #542
kyoo's Avatar
no, not true... we tune both... Motec and other ACD controllers like GEMS are used on rally cars and those have to have a mechanical RS rear diff, hence those controllers do nothing for AYC.. Some rally drivers use mitsubishi Ralliart ACD controllers which are just stock units with diferent setup..
i encourage everyone to read the article i posted from motec....
Originally Posted by kyoo
that's not how most of the evo tuners overseas feel about it -
http://www.motec.com/filedownload.ph...pdf?docid=4399
VCU will react only to difference in axle speed and will change its behaviour when it gets hot.. ACD actually works all the time and is very reactive to steering input, not just wheel speed difference..
exactly... u want to allow the speed difference on corner entry, and lock together on corner exit.. VCU can't provide that
Old Jul 9, 2017 | 05:21 PM
  #543
griceiv's Avatar
I think you need to read your motec article again. the ACD works best (best transient response, best corner exit balance) when it is open...guess what the VCU is closest too?
Anyone who thinks a nose heavy evo needs more stability is doing something wrong.
Old Jul 9, 2017 | 05:28 PM
  #544
kyoo's Avatar
we must have read a different article.
the ACD is best tuned, not open:
Mid-corner on zero throttle, the diff is virtually open allowing the car to be very nimble, while under power there’s a good percentage of locking, close to the safe maximum, enabling the car to powerslide as its nose points in the intended direction. Confident drivers will quickly find that car speed isn’t limited by over or understeer, but by outright tyre grip – the ideal handling balance.
re: stability (under open):
It turns in extremely fast, but the biggest difference – and it is a huge one – is the lack of stability under brakes. From the high-speed corners into the low-speed turns, there is a tendency to lock an inside front tyre – based on normal driving style – and the result is the need to be kinder and softer (and less
effective) on the brake pedal.
i'm going by that comment - i've never run the ACD completely open so I wouldn't know how stable or unstable the braking is without it.
Old Jul 10, 2017 | 01:33 AM
  #545
kikiturbo's Avatar
I have and the car is an understeering POS with open ACD (admittingly, the AYC was off too)
with regards to your motec comment.. I have read the article before and there is no mention of ayc... what I told you before is that we who choose to keep the ayc tend to remap both ayc and acd... Motec on the other hand is ACD only solution becuse the vast majotrity of race cars come with RS rear diffs... i.e. no AYC, so no need for that control.
Old Jul 10, 2017 | 05:44 AM
  #546
kyoo's Avatar
that is very interesting, since the article notes the exhaust opposite with their car - it must be due to the AYC being "off" as well, which is also very interesting. JDM RS's have a clutch type 1.5 way IIRC, so there should be some lock-up on decel, meaning if anything they shouldn't be as loose as an AYC that is not functioning?
the aricle does mention that their tune disables AYC.
In some Evos, the MDC disables the Active Yaw Control, but compensates with added stability from the new diff settings.
this matches what i've seen from other ACD tuners, including when I was speaking with English Racing as they were developing their ACD tune. but as you say, there could be other options. I'd personally love to see a test of stock 9, stock 9 w/ ayc, stock 9 with acd tune and rear diff, stock 9 with acd tune and ayc, think it would be really interesting to see that data.
that reminds me, you're also the second person i've seen mention that your car actually understeers worse with ACD off - and the other guy had a USDM car. very odd indeed, counter to the article's claim that open ACD oversteers more, as well as what I have seen and experienced myself.
Old Jul 10, 2017 | 09:21 AM
  #547
kikiturbo's Avatar
yes, my point was that aftermarket ACD controllers do not work with AYC because their market is mostly rally and other race cars which are mostly run with RS rear diffs.. and not because AYC is better kept off... in fact if you were to try a euro/jdm evo 9 with ayc and a usdm e9 with the plate diff you get, you would see that the ayc car is much more "nervous" and turns in better and tends to oversteer on demand. I am just in the process of setting up a USDM e9 MR and while we did perform the diff restack it still doesnt push the nose in on throttle like the ayc car will.
My experience with acd off might have been due to ayc not working too (the pump was off the car for service) but it is a fact that the ACD is very active in controlling the car. One more thing that I find iffy in the article is that they talk about torque split between axles, and this is not what acd does... it is just a active limited slip clutch..
I also urge you to try logging it.. you will see that is is very active all the time, much more than the usual presumption of it being open on turn in and closing slowly on exit.. It also reacts first to steering speed...
Old Jul 10, 2017 | 10:04 AM
  #548
kaj's Avatar
kaj
Im told my ACD tune leaves it open longer, if I read the emails correctly. Definitely less understeer.
Old Jul 10, 2017 | 10:12 AM
  #549
kyoo's Avatar
We may have some slight misunderstanding in communication here. I know the ACD is very active. I'm not saying the AYC is better kept off either.
Re: Torque split, that is essentially what limited slip differentials do - if there is a speed differential and a diff tries to clamp them together, it will experience a difference in torque distribution. Same between two wheels in the rear. There will be a torque shuffle to the outer wheel.
Also, re: logging the ACD - that is what I am saying. Stock tune, the ACD is active all the time - too active, maybe a safer setting. What the current set of available ACD retunes do is opens up the ACD, particularly on throttle off.
I'm actually glad to hear you are setting up a USDM Evo with rear diff plate restack - no it will not turn like it has AYC - but the ACD is key here. I would reach encourage the owner of the car to reach out to English Racing to retune the ACD. There will be some big differences in how the car behaves, PARTICULARLY in turn-in. The car will turn in much better. I'm curious to see how that feels for you vs the AYC equipped car.
https://www.evolutionm.net/forums/ve...cd-tuning.html
Originally Posted by Darrin
I had the opportunity to test the English Racing autocross tune ACD controller in my 2006 EVO IX today. After several laps at the autocross track I can say it was absolutely EXCEPTIONAL. The controller tuned out all under steer (push) and made car react to inputs better than any evo i have ever been in. I could plant the front end on a cone and get the back end to rotate around unbelievably fast. If I was told i could only have one upgrade to a evo that i was to race, this is the very first thing i would put on my list. It made a bigger difference than my ball bearing turbo, or even my Ohlins . On the lowest setting I picked up 2 seconds (50ish second lap) the next higher setting i picked up another 1 second. The highest setting was the cherry on top. I picked up .4 sec and continued to improve .2 to .6 each lap as i got dialed into it. I had Nationals and Regional winning champions dive my car as well to give me their feedback. They were astounded that it was even an evo, they couldn't believe how much better it was than their nationals winning EVO. Thank you Aaron O'Neal for giving me the chance to try this thing out. I can tell you that as Bremerton Sports Car Club autocross instructor, i am going to recommend this controller to every evo that i come across.
I did re-stack my rear diff and i would say that this re-flash affected rotation 500% more than the re-stack did. I welcome people to come to any BSCC autocross events and i will give the a ride and let them feel it.
Old Jul 10, 2017 | 10:36 AM
  #550
kaj's Avatar
kaj
To be fair, I pick up that kind of time, between runs, as I get used to the course. Hard to compare settings in a situation like that.
Old Jul 10, 2017 | 10:38 AM
  #551
kikiturbo's Avatar
aha, ok, point taken.. we will try some different acd maps for this car.. first we need to fit a stiffer rear arb..
Old Jul 10, 2017 | 10:47 AM
  #552
kyoo's Avatar
That's a fair comment. I don't know the scenario of the testing - if they got to a certain level, then changed it, then hit another wall, then changed it and picked up speed or not. I'm not saying it will, from your fastest run, with just the switch drop 2s. But I'm looking at the rest of the commentary, as well as reviews, and seeing that there is consistent improvement in laptimes. His is just one anecdote, there are many others in that thread.
Old Jul 10, 2017 | 11:11 AM
  #553
LetsGetThisDone's Avatar
I never quantified my results objectively with lap times. But I have swapped a stock ACD ECU in/out of my car at autocrosses and track days, car feels worlds better when the ACD is running the ER tune. Handles much more like a RWD car with all the grip than a pushy AWD when the ACD is tuned.
Old Jul 10, 2017 | 12:08 PM
  #554
kyoo's Avatar
Originally Posted by alpinaturbo
I'll blatantly blow the horn on behalf of knowledgeable but restrained genius,
You should know that Kikiturbo tunes ACD maps, and optimizes others ACD maps, aside from building all mechanicals, turbo kits, porting, tuning, and more.
So be assured his feedback based on the experience with ACD+AYC "rest of the world" Evo, and USDM Evo models, as well as successful rally Evo's which are a lot like USDM- ACD with RS rear diff.
Getting back to FRONT LSD:
I discussed with couple of highly experienced road race Evo chassis specialists, and both advised that Wavetrac is only front LSD they use, and pointed out how plates (wear) material in Plated Mechanical LSD gets into gearbox oil, and generally mechanical LSD plates require different oil(somewahat opposite requirements) oils not recommended for gearbox.
For race car the oil issue is moderate compromise, but for more club level and dual purpose car, Wavetrac is easier the better choice.
As far as performance, neither felt that Wavetrac gave up any performance to Plated Mechanical LSD on track, or road.
This is theirs point of view, their experience, and preferred method.
I don't doubt that, but I also don't think we were in disagreement after initial miscommunication on my part - let me get a mod (that has power in this subforum) to pull the ACD chatter to the ACD thread.
thanks!
Old Jul 10, 2017 | 12:24 PM
  #555
kyoo's Avatar
I had ability in both forums so I was able to pull the ACD chatter out of the front diff talk and move here. thanks all.
