megan racing downpipe rattle
Old Apr 23, 2010 | 11:55 AM
nirvancol's Avatar
Originally Posted by 2006blkevo9
Does it rattle any other time? I had a problem where the little thin bracket that holds the wire from the 02 sensor hit againist the pipe. Made a rattle sound that drove me nuts. Ended up just removing it, and securing the wire a different way, away from the heat and drive shaft. Get under the car, move the exhaust around with your hand, and see what you hear it from.
I had the same issue when I installed my Greddy Ti (only had the catback installed, the rest of the exhaust system was stock). Theres a bracket that is mounted at one of the drive shaft center bearings near the rear O2 sensor. The bracket has two clips that hold the O2 sensor wire away from the exhaust. There are two studs on this bracket, and one of them was contacting the cat back which would sometimes create a rattle at idle. I ended up removing the bracket.
Old Apr 23, 2010 | 09:01 PM
Ryuartz's Avatar
Braydo25
Lancer Troubleshooting
Aug 15, 2015 07:54 PM
Hotshot940
14
Feb 20, 2014 06:11 AM
SuperMoto!
Jan 9, 2011 07:36 PM
krisdlm
14
May 20, 2010 03:16 PM
WADADLIG_OZ
14
Feb 20, 2004 03:57 AM
