Attention All Aluminum Rod Engine Owners....
Old Oct 3, 2010 | 06:01 PM
  #46
dastallion951's Avatar
@jc evo, as far as I know they are aluminum rods.
Old Oct 3, 2010 | 06:40 PM
  #47
Ted B's Avatar
Eagle Rods are steel rods. But that's a good thing. I can't imagine a worse proposition than an Eagle branded (i.e. Made in China) aluminum rod.
Old Oct 3, 2010 | 06:59 PM
  #48
awdturbo8's Avatar
I never heard of eagle making aluminum rods.
Old Oct 3, 2010 | 07:15 PM
  #49
well then i stand corrected hahaha....and thats not common on these boards...haha
Old Oct 3, 2010 | 07:24 PM
  #50
EvoDan2004's Avatar
LOL you have 140 posts. i would hope its not common.
Old Oct 3, 2010 | 07:31 PM
  #51
actually its not very common at all, and honestly i dont got on this site much, only when i cant find what i need on socalevo.net, in all honesty i did think they were aluminum, but you knowing that there steel is relief, at least that, that part shouldnt fail...haha
Old Nov 8, 2010 | 10:30 AM
  #52
MagicManRed's Avatar
Updated... added question... "what oil are you using"
Old Jun 13, 2011 | 06:11 PM
  #53
It's bee 5000 miles now on my motor... updated my info post.
Old Aug 29, 2011 | 08:09 AM
  #54
Nearly 10k on the motor now... Bump to aluminum rod engine owners!
Old Aug 29, 2011 | 08:24 AM
  #55
1UpMoto's Avatar
• When was the motor built?
2009
• What rod bearings did you go with?
Acl
• What rods did you go with?
Groden
• What crank shaft did you put them on?
Oem
• What compression ratio did you choose?
9:1
• What displacement are you running?
2.0
• How many miles of non-boost breaking-in did you do before spirited driving?
I broke it in hard
• What motor oil are you using? Why?
Mobil 1 ep, good reviews
• Who built the motor/what shop?
Myself
• What are you using your vehicle for?
DD
• How many miles are on your vehicle since the break-in?
Almost 30k
• What fuel/boost level are you set on?
Was one 42 psi on a 6262 pump gas and meth, currently on an evo 9 turbo at 34 psi same fuel
Old Aug 29, 2011 | 08:30 AM
  #56
Old Sep 7, 2011 | 12:18 PM
  #57
Robertv34's Avatar
Alright guys back to the top =) I going with a full build on my evo now GRP Aluminum Connecting Rods is what I am looking for What pistons do you aluminum rod guys recommened I want to put Down 800+ I have a built head gsc 272 beehive springs ect... SO revving wont be a problem.....2.0 Is what I want but what compression should I go with 9:1 or something different Let me know what you guys recommened for this setup Im looking to go all out!!
Old Sep 7, 2011 | 12:19 PM
  #58
Robertv34's Avatar
Originally Posted by 1upmoto
• when was the motor built?
2009
• what rod bearings did you go with?
Acl
• what rods did you go with?
Groden
• what crank shaft did you put them on?
Oem
• what compression ratio did you choose?
9:1
• what displacement are you running?
2.0
• how many miles of non-boost breaking-in did you do before spirited driving?
I broke it in hard
• what motor oil are you using? Why?
• who built the motor/what shop?
Myself
• what are you using your vehicle for?
Dd
• how many miles are on your vehicle since the break-in?
Almost 30k
• what fuel/boost level are you set on?
nice!!!!!!!
Old Sep 7, 2011 | 12:42 PM
  #59
Wiseco HD 1400. Those things are nuts.
As for compression... well... more compression, more off-boost power... AND on boost power... if you're running E85 or race fuel... might as well go higher in the compression.
I'm running 10.5:1 on a 2.4 with a ball bearing FP Black on 27-28psi. (30 is pushing it on a chance of bad gas with that compression)
So it depends what you're doing.
Best of luck!
Old Sep 23, 2011 | 05:00 PM
  #60
TurboTravis's Avatar
Originally Posted by JohnBradley
2 reasons.
Proving a point about aluminum rods and oil temps on the streets and weight reduction.
Actually I think Luke took it off to sell to a customer that had a spun rod bearing and needed an oil cooler and didnt want to pay dealer price.
aaron
What are your oil temps after a couple pulls?
