for anyone that has crankcase pressure issues
Old Sep 15, 2022 | 01:13 PM
  #1561
ViciousLSD's Avatar
I updated the diagram since I got some oil on the intake side breather (time attack event) and wanted to make that maintenance-free
Old Sep 25, 2024 | 09:58 PM
  #1562
evoviiiiii's Avatar
Evo VII burning oil
Hello everyone.
I have a 2001 Evo VII that is having some issues. it reads 2psi crankcase pressure @7000 rpm, and is blowing the dipstick out at around 5000rpm. Compression test is 178,180,176,180. It is also makes a puff of oil smoke for about 2-3 seconds after coming off boost. I thought rings but comp is healthy and there is no oil on the plugs. I have also done a valve seal test, i.e; coasting down a steep hill and flooring it at the bottom, however no smoke appeared. Another thing it also takes a while to cold start (around 20-25 cranks), which leads again to the rings. Any help would be greatly appreciated. Cheers
Old Sep 25, 2024 | 10:25 PM
  #1563
LetsGetThisDone's Avatar
The dipstick probably just needs new orings, and PCV valve may be clogged.
Old Sep 25, 2024 | 10:30 PM
  #1564
evoviiiiii's Avatar
Ive replaced the valve and checked all the lines
Old Sep 26, 2024 | 07:45 AM
  #1565
ViciousLSD's Avatar
check your downpipe and intake pipes for oil. the crankcase pressure could be pushing oil thru the seals.
if you dont have adequate venting at full boost then just put a spring to hold down the dipstick.
TariqEvo
Jun 29, 2019 08:59 PM
N3WBI3
Nov 9, 2015 02:47 PM
Khaymael
Jun 30, 2015 05:19 PM
bbyevo8u
15
Feb 2, 2012 09:53 PM
