for anyone that has crankcase pressure issues
Old Jul 22, 2013 | 01:23 PM
  #646
foxbear2277's Avatar
Originally Posted by 240Z TwinTurbo
I am not sure there are negatives, but I did see a member state he was seeing positive pressure coming from the pipe when not on boost. If this is indeed an issue this is easily solved by putting a one way check valve into the system. I would run a closed can as I have been told the exhaust can create a significant amount of vacuum so you want to avoid thick clouds of blue smoke during WOT.
Even with a quality check valve this set up simply does not work. The exhaust simply has too much back pressure... for a drag set up that has the exhaust out the front bumper ect.. it would be fine....
I learnt the hard way... Thought it was a great idea and that it would create great vacuum but ran into nothing but problems
Right now im VTA but contimplating on installing an electric vacuum pump and going to a closed system again.
Old Jul 22, 2013 | 03:30 PM
  #647
Originally Posted by j255c
What kind of check valve do you use?
http://www.boombaracing.com/cv.html
This is what I used
Old Jul 22, 2013 | 03:36 PM
  #648
mrfred's Avatar
Originally Posted by foxbear2277
Those are nifty looking.
Old Jul 22, 2013 | 05:03 PM
  #649
240Z TwinTurbo's Avatar
Not that it matters, but I have data logged back pressure ~1.0" after the turbo when running 40psi of boost and see less than 1psi with my 3.5" exhaust.
You have to run some type of venturi port that extends into the exhaust stream to create vacuum. With almost the complete lack of pressure, at least in my system, and the use of a venturi port I doubt a check valve is even required.
I will test the system and report the data in the next few weeks. I plan to data log pressure and let the data decide. I did just purchase the HAL oil cap breather so I plan to vent that to the exhaust scavenge through a closed can and will post pictures soon once I finish fabrication.
Old Jul 22, 2013 | 05:35 PM
  #650
I have already run that... it was a mess... By no means am I saying take my word, but this was my set up...
https://fbcdn-sphotos-d-a.akamaihd.n...44765321_n.jpg
Old Jul 22, 2013 | 06:09 PM
  #651
Thank you for sharing the pictures and it would appear you had the correct pieces to make it work. Perhaps I should start by hooking up a hose to the port and seeing what type of reading I get from my vacuum/pressure gauge. I should be able to rig up something over the weekend to take preliminary readings.
Old Jul 24, 2013 | 08:08 AM
  #652
evoxsi's Avatar
can i use a check valve instead of a pcv if im not using a catch can for that side of the vc.
Old Aug 1, 2013 | 10:53 AM
  #653
heel2toe's Avatar
Bumping this up. Where can I get a good quality check valve that accepts 1/2" ID tubing and doesnt cost $40 bucks like the ones made by Boomba Racing? Also just to confirm, Im running two catch cans and am still using my PCV. Do I only need 1 check valve in the line that runs from my IM to the catch can that way the can will not be pressurized?
Old Aug 1, 2013 | 02:39 PM
  #654
k1ll4hb33's Avatar
Better off just running a line pre turbo and that will suck everything out.
Old Aug 2, 2013 | 10:22 PM
  #655
j255c's Avatar
why was it a mess, this is what i want to do
Old Aug 2, 2013 | 10:48 PM
  #656
Simply did not work... Oil ended up being highly ingested
Just lucky I didn't blow my new motor.
Still not sure where or why this didn't work, but when I removed the line from the exhaust and left it open to atmosphere the car ran unbelievably better and oil consumption stopped instantly
I plan on running an electric vacuum pump instead now
Old Aug 3, 2013 | 05:56 AM
  #657
I was able to hook up a line to the exhaust scavenge venturi just to understand what happens at idle. I attached a ~3ft aluminum tube and there is minor flow out of the tube so it will require a one way valve or it will send pressure to the crankcase. When I revved the engine to 3k rpm the flow from the tube disappeared, but I did not have a gauge to measure pressure. I have started fabricating my new catch can and purchased the a NAPA 2-29000 exhaust scavenge valve. I will post pictures in my thread and report back my results here.
Old Aug 3, 2013 | 06:43 PM
  #658
211Ratsbud's Avatar
Interested to see how that napa part plumbs in.
What if the scavenge tube had significant more convergent angle?
Old Aug 3, 2013 | 10:05 PM
  #659
j255c's Avatar
goign to run an extended dump breather line under the car then
Old Aug 3, 2013 | 10:49 PM
  #660
joseph143's Avatar
what check valve do you use
I have 10an drilled out on the valve cover from the side and in the back, removed PCV.
Sorry some how i unsub'd just came across the thread... Themuscle car guys have tried
Most valves and recommend a napa part... Its an exhaust check valve... It works great. Under heavy boost i actually start pulling large amount of oil vapor out which bothers me. I'm gonna redesign the system when i get time. I wish i had mrfreds resources to log this thing for everyone...
http://m.napaonline.com/parts/PartsD...001_0174318545
I feel the fitting size is a bit large in my opinion but i was following advice rather then creating my own system so i went with it. If you cant get one with a 5/16-3/8s inlet it would work a lot better.
Just noticed you are running a 5/8s line not a 5/16 like me. This fitting will probably work great for you. Run your breather to a catch can... Baffled would be best... Then to the exhaust to minimize oil vapor... Should work great
Like i said mine pulls oil under heavy boost. Verified by dosconnecting it and it stopped smoking... But so lil it never effected my oil level... Just enough to make a visual haze out the pipe.
Probably what the guy above mentioned as a mess...
Ps if you have more the 1.25psi back pressure your exhaust is busted... Thats the highest allowable by any manufacture in the world... With a cat mind you. If you attempt this with a cat it will melt down and clog your exhaust pipe... The average car should sit around 0 pre cat pressure and 0 thru -4/5 without a cat on a well flowing exhaust.
