Some current oil analysis info, ongoing testing.
I’ve decided to keep better track of my engines health so I’ve started my oil analysis reports from blackstone.
First sample was with Amsoil 10w/30 signature series and it wasn’t too bad. I wanted to switch to rotella t6 again since it’s easier to get the same day and cheaper. Both samples looked great so I’ll just continue with T6 and I plan on pushing the engine a little harder soon.
I agree, by the way. I've always had good results from Rotella. People still like to use expensive fluids because it makes then feel warm and fuzzy, though. Or maybe they have a specific reason they need to use it I dunno. Either way, it's still one of the best-kept secrets in automotive fluids.
For the history of this car it has seen AMSOIL for about 90% of its life and I hadn’t had any issues what so ever. I’ve ran T6 in the past and it was my go to choice if I needed it right away. When I would use T6 it was mostly during summer months when it wasn’t using AMSOIL. During the summer I wanted slightly thicker oil for added safety especially since I was in South Georgia. The car never felt right with 10w-40 but the engine felt good with T6
i do run AMSOIL for drivetrain and always have. Other then a notchy transmission when it’s cold out it’s never let me down lol
It's good that you have a point of reference and data to back your decision, though. Most people are like, "I run only AMSOIL 24/7" but when you ask why, they don't have any quantitative info. Just something along the lines of "I don't like to take chances" or "Because I only run the best". At least your decision, as well as a select few others, has solid reasoning behind it. For those that run W2W/endurance racing or run a bazillion WHP, I could see how AMSOIL could be a necessity. At that level, I'm not sure even I'd trust testing out oils.
At least it's actually a decent oil so people using it should never have a negative experience. I've never heard anyone be disappointed in AMSOIL. It's like using a Rolls Royce to go to the grocery store.
Yes but my oil is never in the pan long enough for a sample. If I sent one in, the oil would at most have a few hundred miles on it. Last time it was back from the dyno the oil was like water I think so much fuel was in it lol so that might be a good time to send it in.
I have used Rotella T6 5-40 over the years in 4 different vehicles including my Evo. Recently there has been a formulation change by Shell and there is some argument whether this is a good or bad thing. The Evo has never used any oil between changes, so there is no difference. On two high mileage BMW's and an old Land Rover Disco there is definitely decreased oil consumption between oil changes. FWIW.
I've always been curious about sending in a sample. Used Amsoil Dominator for the longest time but switched to synthetic VR1 a year ago since it's ridiculously cheaper. Car feels like it runs just as good but don't have any actual evidence to back it up.
