do i need a fuel pump or injectors?
Old Jan 1, 2011 | 06:20 AM
ilikeboost's Avatar
I have an 06 mr w TB exhaust, a test pipe, apexi int & induction box, will have a Nisei or ets licp, I have a hallman rx mbc and aem uego WB and boost gauge. I am cranking up the boost to 24 peak hopefully tapered to 20 and will get a tune thru speedfactory. Do I need fuel mods, ie injectors and or pump for this set up? I know the ix's have better fuel but want to make sure before I show up to the tuner with no gas lol
Old Jan 1, 2011 | 06:34 AM
4RETECH's Avatar
Injectors no. As for fuel pump, the IX pump is good, but I would upgrade it now if future mods will come into play.
It's cheap enough to get anyway.
Good Luck
Old Jan 1, 2011 | 11:16 AM
ilikeboost's Avatar
But as of right now I don't need the pump to run 24 psi
Old Jan 1, 2011 | 01:24 PM
Tuxevo's Avatar
Upgrade your fuel pump. It's cheap insurance and easy to do.
Old Jan 1, 2011 | 04:45 PM
240Z TwinTurbo's Avatar
I installed my Walbro last week and before I did I was logging fuel pressure. My stock IX pump was dropping ~4psi fuel pressure at 22psi of boost. Installed the Walbro and it now holds pressure to red line. You really need to have the ability to monitor fuel pressure to answer your question.
Based on what I saw, you should probably add the pump.
Old Jan 1, 2011 | 05:07 PM
ilikeboost's Avatar
Thanks for the info. So when u installed it do u have to run the tank dry to do it and will the walbro behave the way the stocker will until I get a tune. I will change it myself but will have to drive the car two hours to the tuner?
Old Jan 1, 2011 | 05:45 PM
MR White's Avatar
Subscibed
Old Jan 1, 2011 | 05:47 PM
MR White's Avatar
Why's the fuel pump insurance? I thought the ix pump was good for 350 whp
Old Jan 1, 2011 | 05:48 PM
evolution2186's Avatar
I'll assume you're going to tune on Pump 93 Octane? If that's the fuel being tuned for, you will not need a Walbro for 24psi. Anything beyond this point will require an upgraded pump for more fuel.
Old Jan 1, 2011 | 05:49 PM
The lower the fuel level the better. Try to not have more the 1/4 tank of fuel for the install.
Old Jan 1, 2011 | 05:54 PM
sparky's Avatar
Originally Posted by 240Z TwinTurbo
I installed my Walbro last week and before I did I was logging fuel pressure. My stock IX pump was dropping ~4psi fuel pressure at 22psi of boost. Installed the Walbro and it now holds pressure to red line.....
What mods are on your Evo, 240Z TwinTurbo?
EVOXMR10
Jul 15, 2012 12:22 PM
babaz7
Jul 8, 2012 09:34 AM
vinnieg
Mar 14, 2012 10:30 AM
dadsgts
Jan 7, 2011 12:45 PM
94AWDcoupe
22
Nov 2, 2009 12:41 AM
