New BW EFR Turbo Thread
Old Nov 25, 2015 | 03:53 PM
  #3661
CBRD's Avatar
This is the result of our EVO X RBX 7163 TWIN SCROLL versus (same car) BBX evaluation-
Solid is 7163 , dashed bbx- same car- same dyno, same mods-
please note- this car was always a bit strong on our dyno- even on the bbx lite- but these results just give a nice comparison- ill get some other overlays-
we are considering a T4 IWG evo 8/9 kit since people keep asking- but the manifold design would be drastically different than our current EWG 7163 EVO 8/9 kit-
cb
Old Nov 25, 2015 | 04:34 PM
  #3662
R/TErnie's Avatar
Go EFR and CBRD. Thanks for sharing the data
  #3663
CBRD's Avatar
LOL!
Eric- I fully expected a little harassing- lol-
im still waiting-
Happy Turkey Day Weekend!
cb
Old Nov 25, 2015 | 04:39 PM
  #3664
MrLith's Avatar
Brilliant, thanks for sharing!
Is that stock stroke? E85?
Old Nov 25, 2015 | 05:04 PM
  #3665
CBRD's Avatar
Here is the Car shown-
2010 EVO X GSR
PREVIOUS SETUP WAS:
BBX ball bearing CBRD manifold, Downpipe, test pipe, stock catback, CBRD FMIC, CBRD Charge pipes, ID1000CC injectors, 3 port, tune
NEW SETUP IS:
CBRD RBX 7163 Kit (manifold, 7163, downpipe), test pipe, stock catback, CBRD FMIC, CBRD Charge pipes (refinished in black), ID1000CC injectors, 3 port, tune
Otherwise- its stock block/head/cams/airbox etc-
we will be adding our new 3" intake (we previously only made a cold air- this new one is in the engine compartment with heat shield), and changing the exhaust at some point- should make an EASY 450whp (our limit on stock block on our dyno)..
add 50 whp or so for dynojet numbers!
cb
Old Nov 25, 2015 | 05:58 PM
  #3666
mrfred's Avatar
cb
Pretty impressive boost for boost gain. I'd sure like to see a max effort tune on a dynojet.
Old Nov 25, 2015 | 05:59 PM
  #3667
Erik@MIL.SPEC's Avatar
Is the BBX like a full? Or a B? Just trying to understand the numbers.
But that spool is damn impressive
Old Nov 25, 2015 | 06:28 PM
  #3668
CBRD's Avatar
this particular car was a bbx lite BB ( im at home now lol and in holiday mode but i am 99% certain)
these are 3rd gear pulls BTW- same mivec tables, same timing, etc- basically tried to match peak boost and AFR-
cb
Old Nov 26, 2015 | 04:58 AM
  #3669
mrfred's Avatar
cb
Ah, I missed the "lite" part. What were the wheel sizes on that turbo for the Evo 10?
Old Nov 26, 2015 | 05:51 AM
  #3670
CBRD's Avatar
Id have to go back and look- but it was an off the shelf bb lite-
we never had as consistent numbers from the stock frame options we had- as we are having with these kits- they have all been making 400-440whp...
Im really really really happy with the response and feel of these kits- the TS kit did better than I anticipated- in this application- I would still choose the Vband single if I built a X again- because it has a little more head room-
If we go any larger than these options on the X- it is our Tial Vband kit- with Custom Garrett or XONA Rotor turbos- for big power-
cb
Old Nov 26, 2015 | 07:11 AM
  #3671
mrfred's Avatar
ok, I looked back and couldn't find any solid numbers on wheel size, but it was advertised as a 52 lb/min turbo, so the 7163 should kill it for power. Nice part is that it does so without giving up any low end.
Old Nov 26, 2015 | 09:43 AM
  #3672
94AWDcoupe's Avatar
the lite uses a stock turbine mated to that killer 50 gram comp wheel. so this comparo is really impressive in my eyes. sure looks like the 7163 is an amazing turbo.
Old Nov 26, 2015 | 10:46 AM
  #3673
alpinaturbo's Avatar
Chad
What is the output difference on Single Scroll Evo X VS EVO 8/9 with the CBRD 7163?
Are they both achieving 425whp at 26psi peek?
Old Nov 26, 2015 | 11:15 AM
  #3674
altrix99's Avatar
Something a little strange about that comparo. I thought the BBX-lites spool much faster then that but then I see that its utilizing a stock airbox and oem exhaust system? This would absolutely kill spool and low end torque (and obviously power). I found a ralliart spool log on the bbx-lite with oem catback that spools better then that on 91oct. What fuel and components on both runs?
Old Nov 26, 2015 | 01:01 PM
  #3675
Construct's Avatar
Thanks for sharing that chart, CBRD. Really good to see some results.
Even if the rest of the mods weren't ideal, the post says that the mods were the same for (aside from the turbo, obviously) for the comparison.
