New BW EFR Turbo Thread
Old May 27, 2011 | 11:11 AM
  #451
PATRICK B.'s Avatar
Sorry can't see it well in that pic but is the dump tube still entering close to 90* or did you put a small angle on it?
Sorry to see all the extra fab work needed to get this to fit (down pipe etc) but it is to be somewhat expected when dealing with new turbos and the pumbing needed when goin TS......
I do hope you get a new DP shipped out as i'm a bit skeptical with the mod you did to the other..........hope it doesn't negatively affect performance greatly!
Old May 27, 2011 | 11:36 AM
  #452
acssa's Avatar
That is still 90 deg.... if you want a slip joint and clearance that is how it must be...
So engineer from HATCH said it should not make a noticable difference as it is now.
Even at 15 psi boost...
I did re do that down pipe again today.
Old May 27, 2011 | 06:07 PM
  #453
ScorpionT's Avatar
15psi at what RPM? Controlling the 15psi boost at say, 3000RPM, not much of a problem. 15psi at 6000RPM, definitely a problem.
Each wastegate flow will impede with the other severely. Unfortunately, with the limited space you have coming up with a way to route the wastegates properly wont be easy. You will need to be more creative and come up with a more elaborate solution. In this case, its not the simple route that works best.
Old May 27, 2011 | 10:49 PM
  #454
acssa's Avatar
the big question is if a slip join is required... between the gates.
Old May 28, 2011 | 03:44 AM
  #455
n2oiroc's Avatar
I wouldnt run it without either a slip joint or a flex joint. Im going to be putting a flex joint on one of the sides and run them into a merge collector.
Old May 28, 2011 | 10:56 AM
  #456
acssa's Avatar
i think I got a way.... just finishing the radiator then I will dig in again at the dump pipe...
Old May 28, 2011 | 03:08 PM
  #457
Ludikraut's Avatar
Hey acssa, since you have both a 8374 and a 7670, will you have the ability to test them both on the same engine/car? I'm really curious to see what the spoolup difference between these two is...
l8r)
Old May 28, 2011 | 10:22 PM
  #458
justboosted02's Avatar
here is the downpipe I made for my FR T4 TS setup
just an example of what has been done, i do not run ac
Old May 28, 2011 | 10:40 PM
  #459
R/TErnie's Avatar
Originally Posted by erickponce
I think you can also unplug the crank sensor wich is close to the oil fill cap to crank without starting so that you dont have to pull the plugs.
less work i think
wrong.
If you don't pull the plugs the engine generates cranking pressure and the engine won't spin the oil pump at a high enough speed to build oil pressure to fill the lines.
You have to pull the plugs. I just pull the fuse for the ignition and the injectors.
Old May 29, 2011 | 12:50 PM
  #460
CO_VR4's Avatar
You should pre-lube the turbo before installation. If you pre-lube it, and do as R/T Ernie suggests, you'll be fine with a BB turbo.
Don't think about scrimping and neglecting to pull the fuse for the injectors, or you will be spending hours cleaning your engine bay...
Old May 31, 2011 | 11:09 AM
  #461
acssa's Avatar
new radiator to fit better...
New dump pipe layout.... please see if this is better....before I weld it and stuff up some more good metal...lol
Old May 31, 2011 | 11:55 AM
  #462
SmurfZilla's Avatar
Thats a whole lotta piping. LOL
Old May 31, 2011 | 02:21 PM
  #463
03whitegsr's Avatar
What's the issue with just turning the wastegate down and using two separate pipes?
Old May 31, 2011 | 02:39 PM
  #464
RevMoto's Avatar
Why didn't you just rotate the waste gate instead of making all those unnecessary bends?
It has been a week already guys and none of you have a running car with this turbo that you all have been waiting months for.
Old Jun 1, 2011 | 05:06 AM
  #465
joel3987's Avatar
Sub!
