Evo 8 or Evo 9 first gear for drag?
Old Feb 25, 2011 | 04:58 AM
I4UnderPressure's Avatar
I keep seeing info about the "ultimate ratio" transmissions: Evo 9 1st Evo8/9 2nd, Evo 8 3rd/4th, Evo 9 5th.
I'm trying to gain an understanding as to which first is better for Drag. Wouldn't the Evo 8 higher gearing give you quicker launches and put less strain on the clutch/drivetrain? Sure you'd get a few more mph from the 9 first, but I am thinking from a launching standpoint, and from the numbers, I would imagine that an 8 first gear would be easier to launch than a 9.
Someone humor me.
Old Feb 25, 2011 | 05:26 AM
Fireant's Avatar
Depends on your power, may EVOs spin thru the 9 first gear effortlessly either way, on some though its the perfect ratio to just hook in first.
In some cases a longerfinal drive means less shifting and therefore a lower ET.
It really depends on the car and what your looking for, but its a good option for many to get the longer 9 ratio.
Old Feb 25, 2011 | 07:29 PM
I agree on 3rd and 4th. Hell I was running out of gear in 4th across the line. Thats why I plan on going evo 8 3rd & 4th. I just wondered on the first gear. To me a clutch would get less wear on an 8 on a launch than a 9. Id be curious to hear what everyone is using.
Old Feb 26, 2011 | 07:58 PM
Dragking2189's Avatar
I recommend using Evo ix 1st and 2nd gear ,Evo 8 3rd and 4th with evo ix 5th. It's tye ultimate ratio trans great for the track.
Old Feb 26, 2011 | 08:07 PM
EvoDan2004's Avatar
i run evo8 trans with evo 9 1st and 5th.
i wish i understood gearing. i would consider the 411 final but i really dont get it. i run a stock final.
Old Feb 27, 2011 | 06:22 AM
Fireant's Avatar
Wait so which 5th ratio is the longest?
Old Feb 27, 2011 | 06:38 AM
ranz's Avatar
i have the evo8 5 speed trans and i was thinking at some point to swap my 1rst gear and 5th to 9th 1rst and 5th gears, but i didn't see its worth the money since i don't do 1/4 miles, just friendly drags.
Old Feb 27, 2011 | 06:39 AM
wizzo 8's Avatar
I think if you are stock or have minimal mods the Evo 8 1st gear is good because it helps you get off the line quicker. If you are making a lot of power the Evo 9 1st gear is better because the tires wont break loose as easy and you wont hit the red line as quickly. I know for me 2nd gear comes very quick at the power Im at now. Good for the street but not at the strip.
Old Feb 27, 2011 | 08:18 AM
nightwalker's Avatar
So is 8 1st gear longer or 9?
Old Feb 27, 2011 | 08:27 AM
RunThat's Avatar
Evo 9 first gear is longer by 2% guys! Evo 8 AND 9 have same 2nd gear. Use Evo 8 4th gear since it's longer, and JDM Evo 5th gear since it is a closer ratio to 4th.
Here:http://www.teamrip.com/gear_ratio_options.html
Old Feb 27, 2011 | 08:37 AM
RunThat's Avatar
EvoRatios.zip
Here is an Excel workbook that is VERY useful in determining ALL of the ratio options, etc.
Buguy
Feb 14, 2012 06:18 PM
LakerRaider
15
Jun 24, 2010 10:59 PM
voltexct9a
12
Aug 10, 2008 01:48 AM
CC16
May 12, 2008 06:00 PM
TrinaBabe
15
Jul 19, 2005 01:05 PM
