Here we go again, quiet cat-back clarification needed.
Old Apr 15, 2011 | 10:02 AM
  #226
edogg23's Avatar
Originally Posted by FERNO
Nevermind the sqeaky belt. It goes away once the car is warm for 5 minutes, or when I drive it every day.
http://www.youtube.com/watch?v=5J_Ba2xqHo8
Ohhh WOW! Yeah, the Nexus S does a pretty good job of capturing how loud the car is. That is much more accurate than my first video on page 3 or 4 with my old phone (Nexus One with noise cancelling mic).
So yeah. Unacceptable.
Wow that not only sounds loud but it sounds pretty bad too. Yikes.
Old Apr 15, 2011 | 10:05 AM
  #227
n2oiroc's Avatar
sounds like the muffler packing is saturated in gas.
Old Apr 15, 2011 | 01:45 PM
  #228
FERNO's Avatar
It's not. It was louder than that before the dual Magnaflow setup, and was exactly this loud the minute it was started after having both mufflers replaced.
There is no fuel smell, no black smoke, etc.
I'm not sure of the value of that comment, but thanks for the input?
Old Apr 15, 2011 | 01:50 PM
  #229
n2oiroc's Avatar
it was just an opinion on what could possibly be wrong. as exhausts get older (especially with a rich tune) the packing starts to change. you cleared up that thats not the case so i guess its of no value.
Old Apr 15, 2011 | 03:14 PM
  #230
FERNO's Avatar
haha... I didn't mean your comment had no value to the forum.
It was a good question, and this thread is long, I don't expect you to read through EVERY page.
I just meant that I didn't know where you were going with that comment. You clarified, so thanks for the input.
My car does have a "safe" tune, (read: not lean), so it your comment could have been relevant for the old setup. Someone is bound to read this while searching, and that information may be helpful.
Old Apr 15, 2011 | 08:59 PM
  #231
BluEVOIX's Avatar
Just saw the video. Yes that is very loud. Wow, I dont know why your not having any success. Only thing I can think of now is the cams making that big of an impact. And if what I suspect is true, the only way left to quiet a cam'd car is with a muffler that creates a restriction. OEM muffler with a boost activated dump or varex muffler but I dislike manual motor switches.
Old Apr 16, 2011 | 09:27 PM
  #232
PoloTurbo's Avatar
I feel your pain. It's definately even louder than mine.
An old man got my plate number yesterday and said, I'm going too call the police it's too loud for our neighborhood. I was soo frustrated after all my day of work, thats another story, that I literally when full throttle for at least 10 seconds on the rev limiter. HAHA made my day right there with his face.
I think I'm going too put another resonator and let you know. I "almost" want to go back stock cat back...
Old Apr 17, 2011 | 04:43 AM
  #233
FERNO's Avatar
and it is 5db quieter than before if you can believe that. (according to my phone)
Anyhow, I have decided to go back to stock cams, stock turbo, and stock or Tanabe exhaust, but not in the way you think. I am going to sell my car and buy a stock CT9A. There are a host of reasons, a bit too loud, a bit too stiff, a bit too fast, etc. I've already found two cars that are unmodified, and I have 5 people on a waiting list for my car, and the deal is supposed to go down Monday. They won't have as few miles as mine, but it's just going to be too much work for me to de-modify it, when someone else can appreciate it just the way it is.
That said, see my response to Polo below for my take on why we are so freaking loud compared to you.
That sucks. But I think I figured out why mine is as loud as it is. I want to tell you to stop where you are and think about another option.
When the muffler guy welded the rear muffler in, he cut it as close to the bend as possible, so it bends from the center to the right rear, then IMMEDIATELY mates to the muffler.
While searching for leaks two days ago, I walked from the hood, quiet... to the left fender, quiet... to the left front door, quiet... to the left rear door, quiet. Then I got to the left rear quarter, and the frequency was booming. Then I walked behind the car and it was loud, but not as booming as beside the quarter.
I think that the position of the muffler and the angle of the pipe going into the inlet of the muffler has this tuned in such a way that it is causing a lot of low frequency output. which is amplified at the rear of the car. There is only about an inch or two of straight pipe before the muffler weld.
I have heard a test pipe, Buschur bullet system in person, and ridden in it, and it was much quieter than my car. It was also more built than my car, engine and turbo-wise.
I honestly feel that the complete systems are quieter than our custom fab jobs due to the length and shape of the piping and the material used. I am somewhat convinced that this is the reason BluEVOIX's car is quieter than mine. I would not think that had I not ridden in an sd-equipped car that was quieter.
My suggestion is before you spend money to add another resonator, just buy the Buschur Magnaflow CBE. Then you have a setup like BlueEVOIX, with dual Magnaflow/Bushur hybrid. Worst case scenario: if it is not quiet, pull it back off and sell it used on the forums for $400+, and you are out <$70. If this fixes the problem, then you can sell your custom fabbed piece on the forums to someone who wants a loud, no-restriction exhaust. Also, the mystery will be solved for future quiet exhaust seekers, and even I would consider it for my next car.
That is what I would do. That Buscur Bullet SD with test pipe was so much quieter than mine it was unreal. The owner of that car told me: "man, just buy the Buschur Magnaflow if you want it quiet". So, that's an option to consider, as crazy as it sounds.
Old Apr 17, 2011 | 09:24 AM
  #234
BluEVOIX's Avatar
But I dont think Buschur uses any special magnaflow. Its just a polished 7" width magnflow muffler with a case length of 14" .
Old Apr 18, 2011 | 05:16 PM
  #235
FERNO's Avatar
Finally got it quiet!!!
Old Apr 18, 2011 | 06:53 PM
  #236
BluEVOIX's Avatar
Wow, changing the color and adding a JDM bumper made that kind of a difference?
Is that car stock?
Old Apr 18, 2011 | 07:07 PM
  #237
FERNO's Avatar
lmao. Everyone knows white is the quietest color!!!!
No it's not stock. It has a few bolt ons, an HKS intake, some JIC coilovers in need of a rebuild (good thing I have two sets of MR Bilsteins!) and some other goodies.
HOWEVER! It does have factory cat! and a factory CBE! and OE engine mounts! and no Cusco bracing! Wonder of wonders... it is quiet!
As a side note, the gent who bought my Evo is about 100x more familiar with these cars than I am, and he stated quite plainly that the engine mounts definitely and possibly bracing are causing the noise. So I guess mystery solved?
Anywho, not my problem!!! LOL. I'm loving my new whip! Tire noise and radio static FTW!
Old Apr 18, 2011 | 07:23 PM
  #238
BluEVOIX's Avatar
I cant agree more!
Old Apr 19, 2011 | 12:41 PM
  #239
Jeffs2006EVOIX's Avatar
There are many pages here to read so I am sorry I have not read all of them. But from what I have heard a "good" solution is the WORKS Exhaust system. Go with their Resonator or HFC option. A friend has that set up on his car and is MUCH quieter than my BR setup.
You know, I like the power and the exhaust noise is cool to a point if it helps the car out, but for me? After 8 yrs of driving Evo's the BR exhausts as good as they are, are just plain loud. Don't get me wrong, they do what they claim, make power, but for DD use with kids, and what not, it just gets OLD REAL FAST. I am looking into options myself, but money is tight. Just going back to OEM may be my only option right now.
This link may Help you:
http://www.worksevo.com/store/produc...roducts_id=131
There are different combos you can get, but I would think either the HFC and or Resonator would be the quietest. Or, You "could" send Works your OEM Cat and they can modifiy it to flow better for a fee. Then run their intermediate pipe and muffler. I was seriously considering that. Just where I am, Emissions are a hassle, is why I was considering going OEM only. My M3 Cozzie cams may be coming out Well Good Luck, hope this Helps You.
Jeff
Old Apr 19, 2011 | 12:56 PM
  #240
Read this late, haha, well good for you...Engine mounts huh? I have the Beat Rush Tranny Mount, maybe I will switch my OEM one back on?? mmmm something for me to try today.
Jeff
