EVO 11.5 Hotside, anybody try it?
Old Nov 26, 2011 | 11:04 PM
  #421
siduolocin's Avatar
Originally Posted by mrfred
Anyone have an opinion on whether this would be beneficial for an HTA Green? I guess it could shift the powerband slightly to the right? I am a little leary of the larger wastegate flow opening. It will take a stronger spring and more WGDC to keep it shut. I suppose if the turbine flow is less restricted, it could balance out.
and you will need a stronger actuator.
-std 0.8 bar only got 1.1 bar boost
-1.2 bar act only got me 1.4-1.5 bar of boost
-i am now going with 1.7 bar next week
HKS boost con at 100% and also try to titen the spring
good luck
Old Nov 27, 2011 | 08:08 AM
  #422
sparky's Avatar
-i am now going with 1.7 bar next week...HKS boost con at 100% and also try to titen the spring...
siduolocin: Is your Evo fitted with an HTA Green turbo with the standard MHI 10.5 housing? If so what actuator are you using.
Old Nov 27, 2011 | 08:23 AM
  #423
mean4g63's Avatar
good luck
for whatever reason it sounds like you have a ridiculous amount of back pressure from the turbine wheel to the engine...
I could run 1.5 bar on my stock .8 bar actuator on my stock turbo.
Old Nov 27, 2011 | 10:15 PM
  #424
sparky's Avatar
...you...need a stronger actuator....0.8 bar only got 1.1 bar boost...
Yeah, this seems way wrong. With the stock actuator you were only able to boost to 16 PSI(1.1 BAR)??? Something is wrong, dude!
Maybe you were only able to only able to boost to 16 PSI with zero preload, right? But, that is why the actuator is adjustable.
Old Mar 1, 2012 | 06:04 PM
  #425
Hi Im Vinh's Avatar
bumping an old thread, anybody else ever tryout these housings?
Old Mar 1, 2012 | 06:13 PM
  #426
4wdrifter's Avatar
Even though I don't have my Evo anymore I know this hot side is still running strong on my old car. And it has an 18psi actuator on it for the above discussed
Old Mar 12, 2012 | 05:15 AM
  #427
todd6027's Avatar
ive one machined out for an fp black it will undoubtedly outlast the turbo
Old Mar 12, 2012 | 08:01 AM
  #428
Hi Im Vinh's Avatar
Sucks that FP won't warranty their turbos using this 11.5 hotside :/
Old Mar 12, 2012 | 09:14 AM
  #429
211Ratsbud's Avatar
I never did mail mrfred a piece of that housing.... i should have. All said and done is a clipped wheel a better idea for more top end?
Old Mar 12, 2012 | 02:42 PM
  #430
todd6027's Avatar
so they do otherwise
Old Mar 12, 2012 | 04:13 PM
  #431
RSMike's Avatar
Does anyone know what these exhaust housings are made out of?
They have A3N stamped onto the side of them, but i'm assuming that because they have just copied the Mitsi exhaust housings
https://www.evolutionm.net/forums/ev...-material.html
Old Mar 12, 2012 | 04:24 PM
  #432
211Ratsbud's Avatar
ill ask mrfred if i can still send him pieces to analyze. I literally have a OEM and this 11.5 cut in half ready to send, I just kept slackin off!
Old May 29, 2012 | 03:32 PM
  #433
TXEvo8chris's Avatar
Waiting for results
Old May 29, 2012 | 04:05 PM
  #434
wshihdnevo's Avatar
Mine will be back on the rollers in about 2 weeks for sure. Its been almost a year since I put mine on.
Old May 29, 2012 | 05:15 PM
  #435
211Ratsbud's Avatar
Never did send them pieces ..lol ill let the success stories speak for my bad experience
