Contraindications for using Motul gear 300 in 6spd/TC/rear diff?
Old Jul 22, 2015 | 07:35 PM
  #31
kaj's Avatar
kaj
Originally Posted by Ted B
http://www.penngrade1.com/CMSFiles/F..._BRAD_PENN.pdf
E85 ready oils employ a phase separation inhibitor that makes them compatible with ethanol, particularly in cold climates. Oils that meet the latest API designation (SN) includes this update. Otherwise, check the manufacturer's website for clarification.
hm. something to think about. i rarely use e85 and it doesn't get too cold here. maybe i'll just continue to use the Rotella. i recently rebuilt my engine and didn't see any signs of sludge or other junk. it hasn't let me down yet (used it in my last three turbo cars).
Old Jul 27, 2015 | 04:45 PM
  #32
Grimgrak's Avatar
CI's are no working while intoxicated and steel must have steel toed boots.
Old Jul 28, 2015 | 01:17 PM
  #33
Erik@MIL.SPEC's Avatar
Are you drunk?
Old Jul 28, 2015 | 01:20 PM
  #34
LetsGetThisDone's Avatar
If I didn't drink while I was working on my car, I don't think I would ever get anything done...lol
Old Jul 28, 2015 | 03:17 PM
  #35
kaj's Avatar
kaj
Mental note: don't take any advice from you. LOL
Old Jul 28, 2015 | 03:22 PM
  #36
I've only left something loose once. It was the front pass side sway bar bracket on the control arm. Didn't even put bolts in it. Was wondering why the front of car felt floppy on the test drive.
Old Jul 28, 2015 | 10:59 PM
  #37
kaj's Avatar
kaj
LOL. And I need no excuse.
Old Jul 31, 2015 | 07:01 PM
  #38
mrfred's Avatar
can anyone fine zinc and phosphorus content for the 300v?
i forget the values but its up there with all the other high zddp oils, i.e., >= 1000 ppm.
Old Jul 31, 2015 | 09:43 PM
  #39
kaj's Avatar
kaj
I posted it earlier:
Mobil 1 V twin, zinc--1750 phosp,1600
Amsoil-zinc,1575—phosp 1425
Brad Penn,zinc 1500—phosp 1340-1400
Motul—zinc 1330?-- phosp 1339?
Rotella T6, Zn 1264 ppm--P 1147 ppm
So I think I'll stick with Rotella or maybe Brad Penn for track days in the heat. They all really are close enough to each other for me. No sense in over paying for oil.
Old Aug 1, 2015 | 10:59 AM
  #40
mrfred's Avatar
Full synthetics cost more but their high temperature stability is better than partial synthetics, and for something like a track day where temperatures can get quite high, I think a full synthetic makes great sense.
Old Aug 1, 2015 | 12:00 PM
  #41
kaj's Avatar
kaj
i could see that. i've used Rotella T6 exclusively on all my cars, as has a friend of mine. lots of track days. no issues nor complaints.
Old Oct 26, 2015 | 06:30 AM
  #42
kyoo's Avatar
Yes, ball bearing turbos aren't an issue. Where ZDDP is important is in engine and turbo designs that employ two steel faces that rub against each other at extreme pressures. This applies mostly to flat tappet valvetrains, chain-driven timing gear in some engines, and steel/steel turbo thrust bearings in FP Red and Black turbos. Our hydraulic roller valvetrains, belt cam drives, and steel/brass or roller bearing turbo setups largely exempt us from requiring much ZDDP in our oils.
wow I know this isn't that new of a post but you dropped some knowledge on me this morning
FWIW - I'm mailing out some UOAs today - one with about 40-50 runs of autox and one with 60min of track time - obviously a much different car from you but I'm curious to see the results. All samples on ZROD 10w30 but I may be switching soon...
kyoo
92
Feb 25, 2019 07:16 AM
McRooster
Sep 15, 2017 09:07 AM
Touge Factory
Evo 'For Sale' Miscellaneous
Aug 4, 2017 09:42 AM
mrevo10
15
Oct 12, 2016 01:03 PM
kjcs9
Dec 23, 2015 07:41 AM
