Exedy Triple - Have You Seen This Before?
Old Feb 22, 2013 | 04:56 AM
  #151
Liqquid's Avatar
Originally Posted by MitsuJoe
Exedy changed the design to lower the cost of rebuild. This way they can make a common disc and not only an EVO specific one. This issue has been seen in other gear driven clutches as well so the quartermaster is not the end all to this design and has seen similar hub and spline failures.
Do you know when this redesign to lower costs happened? All seemed to be well in the land of exedy triples then all at once all of these pile up, certainly seemed like a bad batch but perhaps what you found out was when the problem started? What did the old ones look like differently?
Old Feb 22, 2013 | 06:56 AM
  #152
MitsuJoe's Avatar
The only redesign I am aware of that Exedy has done is to convert the hub to use a standard disc. This was done purely to save Exedy money as I don't think the cost of a rebuild really went down at all to the end user. This is shown pretty well here:
http://www.streettunedmotorsports.co...uild_parts.htm
Although from what I have read is that the new hub design is still possible to cause issues with hub wear and input shaft deterioration. Greg if your looking for any parts let me know!
Old Feb 23, 2013 | 04:54 AM
  #153
way2qik's Avatar
Greg - I don't think Dan is running this clutch anymore. I could be wrong but I think he might be going to a AT.
Hi guys. Sorry I have not chimed in for a while. Right now I do have the latest rendition of the Exedy triple in the car. But I just redid a bunch of things on the car and haven't driven it yet, and actually won't drive it until spring time. So unfortunately I have no reports regarding its performance.
Meanwhile if buschur gets the auto working correctly I will be switching to that.
Old Feb 23, 2013 | 04:58 AM
  #154
Sharkbite2000's Avatar
^^^ Everyone waiting for that !!!
Old Feb 23, 2013 | 05:29 AM
  #155
Liqquid's Avatar
Thanks for the update, when you received that, were there any design changes you could tell that would provide an answer, or did the parts look the same?
Old Feb 23, 2013 | 12:51 PM
  #156
way2qik's Avatar
I'm really hoping it works out.
Yes, there were some changes. I took pictures and will post them when I can. I'm out of the USA right now so I can't do it until I get back.
Old Feb 23, 2013 | 01:39 PM
  #157
teribble's Avatar
I'm also running the latest rendition, It seems to be working fine but I'm still having disengagement problems. I've removed the clutch pill, installed a one piece clutch line, and adjusted my clutch pedal. Next is to replace the slave cylinder. It drives great and has no chatter at all, which will make all the parts last longer. I think that's what was killing the boss hubs before. I only have about 100 miles on it at and no track passes. The clutch disengages great when ripping on the car but if you try to shift slow it's not the best. I need to give Evan another call and see what he recommends. They just need to ditch the pull style triple and switch them to a hydro throw out bearing. They know the evo's have a weak slave cylinder and haven't done anything to fix it.
Old Feb 25, 2013 | 03:12 PM
  #158
420a-t's Avatar
Let's see some pics or info of the revisions made!
Old Feb 25, 2013 | 04:05 PM
  #159
tscompusa's Avatar
no issues with mine. i just looked at it yesturday. around 20 track passes and major street abuse (around 8000 miles). power never exceeded 570tq though.
i wonder if i have the new one or the old design. i can take pics if anyones interested when i get some free time.
Old Feb 25, 2013 | 04:31 PM
  #160
Paul Walkin's Avatar
"Old version" has a splined hub built into clutch disc. (1pc)
"New version" uses a seperate splined hub which the clutch discs slide onto. (2pcs)
Old Feb 26, 2013 | 12:11 PM
  #161
teribble's Avatar
That's not 100% correct. The one I got to test has the old style discs with updated floaters. I forgot to take pics before the install but now both floaters have metal springs like the twin disc to help with disengagement.
Old Feb 26, 2013 | 01:09 PM
  #162
High_PSI's Avatar
I hate these overpriced Pieces of poop. They don't last past 30K, just search and how many "Almost new" clutches are being sold, always Exedy. I don't trust them I prefer a heavy pressure plate and be done with it.
Old Feb 26, 2013 | 08:55 PM
  #163
mrboost05's Avatar
i think 30k is asking alot half our motors dont last that long the abuse we are asking the clutches to take is alot and the single disc clutches are not cutting it most people running twins and tripples are making alot of power and launching the car on slicks ect i am not ok with the little bit of life i got out of my first set of dics but i would be happy as **** and feel i got my moneys worth if i got 30k out of it just my two cents.
older style below tom they just sit on the input shaft newer discs have a hub they ride on mine after 1100 miles
Old Feb 26, 2013 | 10:04 PM
  #164
High_PSI's Avatar
I got close to 60k on my XTSS with 460 WHP. The amount if money on labr alone is enough to make you stick with a proper clutch, do many Exedy failures its symptomatic of a poor design that yes is very smooth but doesn't last.
Old Feb 27, 2013 | 08:37 AM
  #165
420a-t's Avatar
Is this the new or old design? I'm guessing old since its about a year or so old now.
I replaced the center with a new one and got new discs, and has held up with 500miles and launching on slicks multiple times now. Fingers crossed!
In my opinion, I feel that if exedy knows the last design didn't work too well, they should give whomever had the first design a hefty discount on the new parts or clutch if we send in our old one.
