Exedy Triple - Have You Seen This Before?
Old Dec 3, 2012 | 02:55 AM
  #121
Poloiceberg's Avatar
Originally Posted by way2qik
OK guys, I just pulled my newest clutch out of the car this weekend. It was ANOTHER brand new Exedy triple, with the HD pressure plate. Clutch has about 4000 miles on it.
Guess what? It looks just as bad as the first one I replaced. This hub design is definitely a FAIL.
Well this is the icing on the cake for me. I'm definitely not taking the chance to rebuild my triple. Any answers to y this happens? Why did exedy change to this new hub design from the old setup on the triples?
Old Dec 3, 2012 | 02:57 AM
  #122
Originally Posted by Mid_Evo
Right after I posted the pics above I ordered the QM 8 leg and the HRB, threw it and have about 200 miles on it, it amazing, so smooth and effortless to shift, holds the power great (630/540) grabs right away, LIGHT pedal feel super easy to DD. Its not very loud, its not overly aggressive, granted none of that **** bothers me but i still notice haha.. great clutch great design and it being half the price was real nice
Hey I'm guessing you got the street/strip version? How bad/hard was installation?
Old Dec 3, 2012 | 04:30 AM
  #123
AngryEvo8's Avatar
Time for the QM 8 Leg man
^ This! You want Easy driveablity get the street version. Weekend warrior track monster get the race. Be done with stripped hubs/popped tobs.
Old Dec 3, 2012 | 05:40 AM
  #124
AreSTG's Avatar
oh snap, I must have mis-read the thread. I thought the old design was the one failing in here, and the new design was better.
Do I have it backwards, and it's the newer ones failing? If so, I'll have to keep an eye on mine though it seems fine for now...
Old Dec 3, 2012 | 06:34 AM
  #125
MitsuJoe's Avatar
Exedy changed the design to lower the cost of rebuild. This way they can make a common disc and not only an EVO specific one. This issue has been seen in other gear driven clutches as well so the quartermaster is not the end all to this design and has seen similar hub and spline failures.
Old Dec 3, 2012 | 10:00 AM
  #126
Mid_Evo's Avatar
I got the the race version, I only only plan on going up in power so I wanted the 900 Ft/lb Tq rating over the 600 that im already barking up. and as far and the intall went it was super easy, not complex at all, putting the clutch itself on was easy, putting the hydraulic bearing on was super easy, shimming and doing the clearance was kind of a pain in the *** because the math kept coming out funny and then I realized the equation in the directions was still written backwards but... once all that was done it was simple, nothing overly complex, and bleeding the bearing was way easy
Old Dec 3, 2012 | 10:05 AM
  #127
Mid_Evo's Avatar
haha yea, screw all that nonsense so over it all too, but to be honest, the race version drives really well too, its not as aggressive as people make it out to be. I havent really noticed or been phased by anything this clutch has done.. and in all honestly as soon as I drove it i was putting way too much effort into everything, like everything is just lighter and easier compared to the triple, Its like butter, all over it lol
Old Dec 3, 2012 | 10:15 AM
  #128
Mid_Evo's Avatar
The new QM design is way better though on the hub design
1) the gear is WAY bigger
2) A LOT more and smaller teeth on the hub giving it a tighter fit and more surface area the disperse the load
3) the hub is attached to the disk closest to the motor and only the other disk moves freely around. This makes the entire overall design was stronger and less moving parts. and yes everything is going to fail and nothing is the end all be design esp with there are so many factors at play, but the overall design is a significant improvement over the Exedy
Old Dec 4, 2012 | 06:59 PM
  #129
Any definite answers as to why this happens?
Old Dec 4, 2012 | 07:03 PM
  #130
mrboost05's Avatar
wondering why a exedy rep has not came on the fourms and posted there thoughts they were very helpful over the phone last time i had to deal with them i will be pulling my tranny this week with a update.
Old Dec 4, 2012 | 07:08 PM
  #131
MitsuJoe's Avatar
I would suggest a Rockwell hardness test on the input shaft and the hub.
Old Dec 4, 2012 | 07:14 PM
  #132
Mid_Evo's Avatar
ok so my shop thats helping me with warranty called exedy and they said it was due to the clutch pedal adjustment...
they said if you have too much travel in the pedal itll allow too much room for the disks to move around and cause the issues
but i dont really buy that because the hub is only messed up in a small area of where the disk would be .. and how does an in out motion effect the disk when pressure is put on the hub .. i think the metal is just too soft on the hub and isnt standing up properly
Old Dec 4, 2012 | 07:34 PM
  #133
tscompusa's Avatar
my triple HD has been fine.
Old Dec 4, 2012 | 07:59 PM
  #134
mxguy1286's Avatar
Here is what i was told when I had this issue with my clutch after only 5500 miles.
That issue show is caused by a mis-alignment issue. This could be loose or missing bellhousing bolts, a bad input shaft bearing, loose or improperly torqued pressure plate bolts, over adjusted hydraulic system.
Sincerely, Evan Cline
Technical Coordinator-Aftermarket
www.exedyusa.com
800-346-6091 ex633
734-397-6633 direct
All of them issues were not the case. Trans was fresh with about 7k on it, no loose bolts, nothing improperly torqued and nothing over adjusted. No matter what the real cause is it will never be on their end.......
Old Dec 4, 2012 | 10:06 PM
  #135
teribble's Avatar
The problem is caused by not having a pilot bearing which will allow more play in the input shaft. I spoke with exedy on the phone today and it sounds like they're working on a fix. I'm not sure if this is true but I sure hope so. It seem like the metal is just too soft and rolling over very easy or i could see the misalignment being a issue even if it's out the smallest amount it would cause excess vibration and wear the huds likes its doing. I really have no idea just hope they get it worked out in the end!
