INSTALLED: EBAY Civic Half Size Radiator!
Old Feb 16, 2013 | 04:31 PM
  #226
10isace's Avatar
I made a custom bracket to hold my ebay radiator at the bottom. I used a Torque Solution upper Radiator bracket that I had to drill into the frame support. Hope this helps.
The diameter on the ebay one is a little smaller. I didn't have a problem since I use Gates Power Clamps.
BTW, my new one is a Koyo that is modified by/for STM that fits perfect, but cost a little more.
Old Feb 17, 2013 | 03:49 AM
  #227
NARossi's Avatar
Originally Posted by PatricksEvilEvo
So you have your Prosport temp gauge sensor on the bottom or hot hose? I put it on the top ?
Also I want to know with this DNA radiator on the Evo, are the holes the same size to use OEM replacement Samco hoses without a problem or ?
Also want to know if the bottom/top mounting brackets are the same on the Evo and Civic, I'm worried a bit, I'm about to order this radiator while my car is apart. Not a dd but it's driven quite a bit in the summer including racing.
The hoses are a hair larger than the radiator inlet/outlets, but nothing a tight clamp won't fix. I had to make an upper bracket out of a piece of scrap aluminum I found. Nothing special, just drilld a couple holes in it. And yes, temp of the bottom hose. That's where your oem thermostat housing picks up the temperature as well.
Old Feb 17, 2013 | 10:27 AM
  #228
PatricksEvilEvo's Avatar
$52 bucks...
http://www.amazon.com/92-00-Manual-A.../dp/B006RBN8JG
Old Feb 17, 2013 | 01:05 PM
  #229
STLEVOIX's Avatar
Just installed a blox front motor mount with my half radiator. I will say i would recommend getting this as the lower hose does not touch the motor mount, actually i can fit a finger between the new blox mount and the stock lower hose.
Old Feb 17, 2013 | 05:29 PM
  #230
LookThatsMe's Avatar
Would you be kind enough if you went in their website and send me a link? I have used ebay in 2yrs and my account got canceled? I would really appreciate it
Old Feb 17, 2013 | 05:45 PM
  #231
With my T3 turbo kit ill say I'm 1/2"" from my rad. Unless I get stiff mounts I need a alternative choice
Old Feb 17, 2013 | 06:55 PM
  #232
10isace's Avatar
Looks decent. Some of them come with a slim fan. Just be aware when making a purchase.
Old Feb 18, 2013 | 07:49 AM
  #233
NARossi's Avatar
Lmfao at your avatar
Old Feb 18, 2013 | 08:25 AM
  #234
Well I figure if I'm going to have to fab anything up I might as well go with the least expencive one I find, as long as it's going to cool properly. I'm usually the very last person to order cheap parts for my car but if it'll work, why not?
Old Feb 18, 2013 | 08:27 AM
  #235
Originally Posted by narossi
lmfao at your avatar
lol
Old Feb 18, 2013 | 10:52 AM
  #236
MRowens's Avatar
This is very useful
Old Apr 3, 2013 | 02:57 PM
  #237
TSTARKZ123's Avatar
Has anyone tried any of the Civic radiators that come prefit with the shroud and fan? I was contemplating the below with the upgraded fan.
http://www.neukin.com/Honda_Civic_Ra...icradiator.htm
Old Apr 3, 2013 | 10:14 PM
  #238
10isace's Avatar
That looks like the same thing everyone is running but with a shroud. Shrouds, IMHO, are better at cooling the entire area the shroud covers versus just where the fan covers. Looks good.
Old May 12, 2013 | 07:33 PM
  #239
STALIZE's Avatar
Just saw this, but I bought a new 3 row alum civic rad the other day. I'm in Alabama so I'll need all the help I can get. For those that need a reference the depth of the core is exactly flush with the end tanks.
Old May 17, 2013 | 11:16 PM
  #240
Got my DNA rad and slim fan today. It seems like a nice inexpensive part, hopefully it does a good job. I bought it right from DNA, cost me $114 shipped.
