INSTALLED: EBAY Civic Half Size Radiator!
Lower hose, close as you can to the head. The OEM coolant temp sensor that triggers the fans, the same one that the ecu reads is the larger one. Evoscan reads from the larger one, this is just for the dummy gauge. I haven't even grounded it yet, I've been reading my temps in evoscan. Haven't touched 200 yet, but it's cold here
So with this setup you drill a hole in the chassis between the stock intake air inlet holes to mount the radiator bracket?
I have a 12" fan that came with a kit around 935rms with Mishimoto hoses, thermostat and civic rad should this be ok to keep her cool?
Yes and yes, as long as everything is in good working order. Why the Mishimoto hose? Is it straight?
Bump for a great thread. Happy to see that people are able to dd thid setup without any problems.Ordering my setup this week. Half rad, slim fan and a bottle of water wetter. Replacing a cracked oem radiator so I might as well free up some room while I'm at it lol
Also I want to know with this DNA radiator on the Evo, are the holes the same size to use OEM replacement Samco hoses without a problem or ?
Also want to know if the bottom/top mounting brackets are the same on the Evo and Civic, I'm worried a bit, I'm about to order this radiator while my car is apart. Not a dd but it's driven quite a bit in the summer including racing.
