Evo 8 engine oil leak
Old Sep 11, 2012 | 10:16 AM
bbong's Avatar
I'm not sure where the oil is coming from, I found a little bit of it on top of the tranny, which is weird I mean air could have blown it all over the place but it being on top of the tranny is weird, and battery tray -- I'll go and get some oil dye as it does look like engine oil.
Old Sep 11, 2012 | 12:09 PM
dastallion951's Avatar
for the longest time with the help of my shop my car goes too we tried to diagnose the oil leak, after multiple checks, and using oil dye in the engine, turned out the backside of the head between 2&3 was seeping the oil along. So my head gasket had to be redone. So im not saying it is in your case, but I wouldnt rule that out either.
Old Sep 11, 2012 | 01:55 PM
bbong's Avatar
Yeah, engine looks very clean, it's the oil on top of the transmission dripping down to the sump, collecting on the bolt-heads just like the OP has it.
Old Sep 12, 2012 | 04:49 AM
bbong's Avatar
I think I found mine, it seeps around the oil pan and bolts, onto the bolt heads, down on the dp and there's the smoke.
Old Sep 12, 2012 | 06:46 AM
Danjul89's Avatar
In my case it was the oil pan that was leaking, reglued it, still leaking and then i went to a friend's shop and he glued it, no more leaking oil! woop woop
Old Sep 12, 2012 | 09:33 AM
bbong's Avatar
Awesome stuff, win for you! I'm going to attempt re-gluing it tomorrow with some magic bond
Old Sep 12, 2012 | 09:55 AM
evoe85's Avatar
seams to me the rear main seal o ring
Old Sep 18, 2012 | 04:43 AM
bbong's Avatar
Well in my case it wasn't an oil pan, but I found what it was and it was a oil feed line for the turbo, where it bolts to the head, wasn't torqued well enough and started dripping oil towards the bottom, which seemed like a leak from around the oil pan area.
Old Dec 29, 2015 | 04:28 PM
Dairon Moya's Avatar
Leak oil next to the transmission
I need help guys any one knows how to fix this or know why am i leaking oil please
Old Dec 29, 2015 | 05:04 PM
LetsGetThisDone's Avatar
That looks like just some residue, not a leak.
And FYI, your car is missing the bellhousing cover, you should get one..
Bhsj13
Dec 18, 2017 08:19 AM
Robertv34
38
Oct 21, 2017 06:44 AM
SH0F
Feb 18, 2017 02:12 PM
SH0F
Feb 18, 2017 02:02 PM
thebigp11
Feb 7, 2017 10:11 PM
