flutter during spool up or is it?
Old May 11, 2012 | 08:29 PM
whitersevo's Avatar
OK I have ruled out that it is the diverter valve because I have the stock IX on there. Yes, the car is tuned properly as well. So, what happens is during wot at low Rpms the Turbo will spool and then start to flutter like crazy And then stop completely. Any suggestions?
Old May 12, 2012 | 05:25 AM
GG06MR's Avatar
It could still be the stock diverter valve if it's now leaking. Replacing my stock IX DV with my APS DV fixed my flutter issue a couple years ago.
Old May 12, 2012 | 06:38 AM
tsidrift1's Avatar
Flutter during spoolup usually is compressor surge, correct??
Old May 12, 2012 | 09:21 AM
whitersevo's Avatar
Correct on compressor surge what's a cure for it?
Old May 12, 2012 | 03:57 PM
jayg4u's Avatar
Veteran: Air Force
maybe something on the exhaust side. one of my friends had a bad wastegate spring and he had surge issues.
Old May 12, 2012 | 07:39 PM
GG06MR's Avatar
Chad Block can explain it way better than me, but he has led me to believe otherwise. Or more precisely, that most people mistake flutter for compressor surge. I did.
Old May 12, 2012 | 07:56 PM
n2oiroc's Avatar
does it happen in 1st, 2nd and third gears or just when you are in 4th or 5th on the freeway at fairly low rpm, but wot?
Old May 12, 2012 | 09:24 PM
TigOLDBiTTies's Avatar
its your wastegate actuator going bad. get an fp 18 or 25psi WGA, it should fix all flutter.
Old May 12, 2012 | 10:00 PM
deylag's Avatar
Did you do a boost leak test?
Old Nov 2, 2012 | 10:57 PM
gotspeed's Avatar
+100000000000000000. for the answer my only happen in 4th and 5th WOT at low rpm.
tsitalon1
61
Feb 28, 2019 02:44 PM
Bananayellowevo
Nov 25, 2016 09:16 PM
J Yim
Jan 25, 2016 01:00 PM
mczellers
Apr 24, 2015 06:59 AM
jesterEVO
48
Dec 15, 2005 05:37 PM
