View Poll Results: Was this thread helpful?
Hell yes! Very useful for the community!
321
98.17%
No way, I still don't know what filter I need!
1.83%
Voters: 327. You may not vote on this poll
The OFFICIAL Oil Filter Testing and Results Thread (4G63T/4B11T)
Old Apr 11, 2013 | 06:14 PM
  #181
lv05evo's Avatar
Originally Posted by bitterchild
the fatty purolator pure one synthetic media filter is available on amazon for $5.xx w/ free shipping over $25 for those who want to run extended intervals
The pure one is not synthetic media, the blue ones are though.
Old May 8, 2013 | 11:14 AM
  #182
evoyang87's Avatar
Just ordered AMSOIL along with the filter. Not too sure how long it will take to get here, but thank you golgo13 for the informative thread!! Also, thank you apagan01!
Old May 31, 2013 | 12:56 PM
  #183
golgo13's Avatar
EvoM Community Team
Veteran: Navy
If you are talking about this filter:
It's a synthetic blend.
Old Jul 16, 2013 | 09:35 PM
  #184
4g63Moon's Avatar
uhh i always used oem filter, literally bought like 4 oil filters at a time haha. Thanks to you, i will be using amsoil from now on.
Old Jul 17, 2013 | 11:16 AM
  #185
TommiM's Avatar
Or get the royal purple and have extra cash in your wallet. The Royal Purple did just as well as the amsoil, but costs less.
Old Jul 17, 2013 | 08:31 PM
  #186
kyoo's Avatar
^ nono.. buy my oem filters off of me...
Old Jul 17, 2013 | 08:40 PM
  #187
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Old Jul 19, 2013 | 11:49 AM
  #188
apagan01's Avatar
You welcome...
Old Jul 20, 2013 | 05:53 PM
  #189
Maj3st1k's Avatar
Would u guys say the RP filter is worth the price difference from a purolator?
Also for RP autozone is coming up with part number 10-2808, different from what's posted here.. can anyone confirm? Thanks.
Old Jul 20, 2013 | 08:18 PM
  #190
TommiM's Avatar
Yes, it should be the shorter,fatter one. I sent Golgo evo 8 filters but the application shows that if you order for evo x you get the shorter one which is the better one. Their application for the evo x filters also fits evos 8-9 btw. The shorter ones are wider and should have more surface area making them better.
IMO yes it would be worth it. A few extra bucks for better filtration and synthetic media. But the Purolator is also a good filter.
Old Jul 21, 2013 | 03:50 PM
  #191
GG06MR's Avatar
Just a little feedback about the AMSOIL filter. Since switching from the fatty Wix to the slim new model AMSOIL, I am seeing on average a 1-2 psi oil pressure increase at idle. No other changes whatsoever.
Old Jul 22, 2013 | 03:21 PM
  #192
golgo13's Avatar
EvoM Community Team
Veteran: Navy
That makes sense.
A smaller housing would increase oil pressure a couple of PSI, which is almost all cases is nominal.
Old Jul 27, 2013 | 01:12 PM
  #193
lv05evo's Avatar
FYI, Fram Ultra(XG9688, short fat one) is also synthetic media with wire backing. It's $9 at walmart. Wix now has a synthetic media filter, it's the Wix XP line. Napa uses the Wix XP for their Platinum line. I don't know part numbers for the XP or Platinum lines, but the platinum is on sale for $7.54.
Old Aug 25, 2013 | 08:10 PM
  #194
Joey B's Avatar
Veteran: Air Force
Hey golgo13 - would you be willing to do another filter test if someone sent you additional filters?
I picked the Baldwin filters a while ago because of a similar test run a long time ago by a Mopar guy. Couldn't find everything (as I don't remember the exact URL) and have to hit WayBackMachine to get the few links I did still have.
http://web.archive.org/web/201110072...ers/index.html
Here was a previous one before it moved -
http://web.archive.org/web/200501130..._filter_study/
A lot of the info here follows what you have also discovered. He gave his opinions why some were horrible and others were good or great.
One thing that I haven't found yet to explain - is that there are manufactures that will give different part numbers on their oil filters for the different years of Evo's.
That is to say - one number for the 2003/04 year, different one for 2005 year, and another different one for 2006 year.
I'm not sure I've found why this is? Are there different requirements for the 4G63 on these years that isn't totally public? Or did I just miss a thread about it that explained the difference in needing a different oil filter between these years?
To me they all have the proper requirements to fit all models - so just pick the one that is the largest in filter size (unless you are REALLY low to the ground - then that may not be a great choice)
Thanks a ton for doing the hard work!! Great read brother!
Old Aug 26, 2013 | 10:37 AM
  #195
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Most of my test equipment has long since been put away, so it would take some real coercing to convince me that you have a filter that's better than the Royal Purple or AMSoil filters I've tested.
I've seen that site before actually, some good info there.
So, what I think is happening here is the confusion caused by the two different models that share the same name and motor.
Lancer and the 4G6X.
Filter manufacturers are probably just getting confused.
Personally, I would just try to find a filter that is as close to OEM spec (See the DENSO filter in this test) and go with that. The size of the filter will change oil pressure characteristics, but not by a huge margin. Not enough to be a problem as far as I can tell*. As I mentioned above, the more media surface area will allow the filter to capture more contaminants, allowing for a longer OCI.
*I'm not responsible for what happens to your car if you do not run an OEM spec filter.
No worries, glad it is somewhat useful!
