400 Fuel Pump Pressure setup
Old Jan 21, 2013 | 07:49 PM
Mrauto50's Avatar
Ok Guys,Need some wise advise. I just installed a MAP 2.3. I also installed a wally 400 E85 version with a 6an feed line to rail. With the rewire.The pump was installed in to my stock hanger by MAP. My fuel setup consist of a FIC 1250 injectors, FIC fuel rail and a Fuel Labs FPR. We fired the car up with a base tune by "The Man"Tom. The fuel pressure jumped to 90psi. We couldn't get it below 65psi. I contacted MAP and talked to Nick. He advised me to drill the return on the stock hanger. He said it would get me around 55psi. I had a very nice member (TED)here to walk me through it. It got me down to 55psi. I was advised to get it down to 44psi with the a 6an return. So I added a 6an return. Now I was able to set the pressure to 44psi without the vac hose and at Idle I hold 36psi. I have always read and Tom even feels a 6an feed & return is not a good idea. In this case If I go any smaller on the return the pressure gets uncontrollable. What would you guys do in this case?
Old Jan 21, 2013 | 08:23 PM
240Z TwinTurbo's Avatar
The stock supply line will be fine as a return line. I cannot comment on whether an undrilled factory siphon will create issues.
Old Jan 21, 2013 | 08:51 PM
Mrauto50's Avatar
[QUOTE=240Z TwinTurbo;10618780]The stock supply line will be fine as a return line. I cannot comment on whether an undrilled factory siphon will create issues.[/QUOTE
Can I do this for the long run? Does anyone know someone running same size return & feed?
Old Jan 22, 2013 | 05:51 AM
Mrauto50's Avatar
Has anyone else done this?
Old Jan 22, 2013 | 05:52 AM
Ted B's Avatar
There should be no issues whatsoever using both a 6 -AN feed and return.
Old Jan 22, 2013 | 08:29 AM
mrfred's Avatar
Originally Posted by ted b
there should be no issues whatsoever using both a 6 -an feed and return.
+1
Old Jan 22, 2013 | 11:36 AM
Mrauto50's Avatar
Cool! Thanks Ted!
Old Jan 22, 2013 | 11:48 AM
itsmrrizz2you's Avatar
I have a -6 feed and return no issues and my fuel pressure adjust fine
Old Jan 22, 2013 | 06:52 PM
Mrauto50's Avatar
Thanks so much guys! I spoke with MAP today and they said they recommend 6an both ways for this pump,
Frasch
Oct 13, 2016 08:22 AM
YFZracer32
Oct 19, 2015 12:03 PM
Moore Auto
Evo X Dyno Results
19
Sep 4, 2015 01:53 AM
Ted B
146
Aug 12, 2015 11:45 AM
nwa7265
Jun 8, 2012 01:32 PM
