Making Your QM Clutch Street Friendly..
the accumulators work VERY well at reducing harshness. dont let EVODAN feedback steer you away. his was likely never bled correctly. the cylinder needs to be mounted vertically. if there is any air left in the cylinder the clutch will indeed work worse. air is very easy to compress. brake fluid is not. a little air in system goes a long way at killing proper actuation.
Correct, once it is bled, you can mount it as you wish. If you have a power bleeder [ The type that hooks to a air compressor ] you can bleed any system in any configuration.
Don
http://www.ebay.com/itm/MityVac-6830-Air-Vacuum-Brake-Bleeder-Kit-/191582365303?hash=item2c9b32e677&item=191582365303&vxp=mtr
This type also works well.
http://www.ebay.com/itm/Motive-Products-0101-Power-Brake-Bleeder-2-qt-Capacity-Kit-/191268124092?hash=item2c8877f5bc&item=191268124092&vxp=mtr
My setup was blead correctly. I tried it both ways. I had it vertical and also used a power bleeder and still no change. The car was just as bad to drive.
However a buddy of mine gave me some info on pivot points and such which now the car is a lot easier to drive. You have to mod the pedal for this. Its also FREE and worked way better then this setup did.
so we have a choice. believe evodan this mod does nothing and maybe makes it worse. or believe the other 100 who love it. your choice.
if it was bled correct, great. then you did something else wrong. there 100s who have done this and love it. you were the only one who didnt get the desired results.
Anyone else have to constantly adjust pedal height with the QM 8 leg?
I wouldn't say this is the end all solution for the QM 8 leg (although the only solution). It is grabby by nature and rough as all get out. Nor does this mod make me "love" my clutch. However, one should know that when they bought this clutch it is a race clutch, not anything else. Launching and shifting is golden!
Let us know how it feels!
Bringing an old thread back from the dead...
I just ordered the QM 8 leg and I understand one of the lines from the HTOB goes to the cylinder the other is a bleeder but the line that comes back off the cylinder where does that go? If someone has pictures where it hooks up that would be great!
I figure out how to make the QM street friendly. Got rid of that pos and got a exedy triple. Imagine being able to actually slip the clutch and it's not an on/off switch unlike the QM. The triple drives like a oem clutch. Let a few buddies drive the car and they thought it had an oem clutch in it lol.
What was the part number of the Exedy Triple you got? Also any long term comments?
Clipse3GT
Jun 24, 2018 09:47 PM
evo8vz
Aug 23, 2017 02:44 PM
manthny18
Apr 21, 2017 10:11 AM
Martispeed
May 10, 2016 08:48 AM
