Buschur Baffled Modified OEM Oil Pan Question
Old Jul 2, 2013 | 01:29 PM
  #61
mrfred's Avatar
Originally Posted by golgo13
I'm looking to run the Buschur piece and a crank scraper for peace of mind.
Is Cosworth the only option for a stock bottom end?
I assume you mean the crank scraper. I believe that I bought a Tomei crank scraper. Can't remember for sure...
Old Jul 2, 2013 | 01:42 PM
  #62
ExViTermini's Avatar
Just as some input, the 4g64 block I used did not have the threaded hole on the flywheel side of the girdle. The boss was there but it was not drilled or tapped, so if you plan on running a scraper with a 4g64 block plan to have that addressed. I was irritated when I went to assemble mine, ultimately just decided to run without mostly due to laziness.
Old Jul 2, 2013 | 01:54 PM
  #63
golgo13's Avatar
EvoM Community Team
Veteran: Navy
The Tomei looks like a nice piece.
boomn29
Jul 8, 2019 05:09 PM
David Buschur
83
May 27, 2016 07:39 AM
maknuge
Oct 20, 2015 01:07 PM
rs03evo
Sep 25, 2013 11:25 PM
Pure EvoIX
Jul 24, 2013 10:28 AM
