View Poll Results: Which do u prefer?
Works P2 Brain ecu upgrade $600
63
20.79%
Vishnu Xflash ECU upgrade $400
71
23.43%
Dynoflash Ecu Upgrade $200
169
55.78%
Voters: 303. You may not vote on this poll
Owners of Xflash/DynoFlash/WorksP2 plz read
Old May 18, 2004 | 09:43 AM
  #151
jansolo's Avatar
You can gain as much or as little as you want with a load bearing dyno. It's all up to the person running it.
Old May 18, 2004 | 10:49 AM
  #152
ez76's Avatar
other dynos' results can be fudged as well, just as easily. there's a whole lot of configuration parameters that aren't displayed on most printed dyno graphs.
Old May 18, 2004 | 11:07 AM
  #153
boomn29's Avatar
Originally Posted by evoindahouse
At the Dyno Day here in Atlanta the xede / xflash made 30-50 MORE whp on a DynoDynamics then the dynoflash, 3 were tested and all made more power when they got rid of the dynoflash.
xflash/xede combo: $1000
Dynoflash: $300
I'm not saying I believe the numbers....but that seems like a really fair comparison...
Old May 18, 2004 | 11:08 AM
  #154
XRS-Lift's Avatar
Dynoflash: $300
um, dynoflash = $200. if u want a custome dynoflash tune its usually $550 or sometimes he has it at $450
Old May 18, 2004 | 07:46 PM
  #155
dmans_evo's Avatar
Damn...so which one to get ? I want the biggest power gains with the most reliable product...but then again, I guess people in hell want ice water....
Old May 18, 2004 | 07:54 PM
  #156
is300's Avatar
I made 42.8 WHP extra from Custom tune X-Flashed($595) from at the Altanta Dyno day
Old May 18, 2004 | 08:01 PM
  #157
dmans_evo's Avatar
with what mods ? and can I go somewhere in cali to do this ?
Old May 18, 2004 | 08:05 PM
  #158
93h22cvc's Avatar
check out al &dyno flash i have never seen him have an unsatisfied customer and he offers a money back gaurantee. al can definately get you power and torque gains. dynoflash is definately the way to go. with over 450 cars tuned i think that speaks for it self
Old May 19, 2004 | 10:39 AM
  #159
XRS-Lift's Avatar
I had Al "Dynoflash" my car and
it feels really good. Im about to find out how much power i got today when i go to the drag strip. If u have a problem with the flash for any reason Al is willing to take care of u quickly.
Old May 20, 2004 | 01:25 PM
  #160
boomn29's Avatar
I don't want to start a #'s debate, but I have to bring up an important point. There's a big difference in peak hp and the actual look of the power curve. A flashed car that gained 50whp could be slower than one with a better curve that gained 35whp. It all depends on when the power comes on in relation with the torque and when/if it fades away.
Just don't fall into the trap of the single highest number. If you say reliable, I think that's a step in the right direction.
G/L
Old May 20, 2004 | 01:28 PM
  #161
boomn29's Avatar
Ok, so we'll say Dynoflash tuned @ $500 vs the Vishnu xflash/xede combo of $1000.
Not real accurate.
Old May 20, 2004 | 01:42 PM
  #162
Event-Horizon's Avatar
I gained 35+ HP with the XEDE/XEDEflash after a base of 210HP with mods. Its like driving a totally different car.
Old May 20, 2004 | 02:02 PM
  #163
XRS-Lift's Avatar
the only way to really prove whos the best is to get ONE evo, all 3 of the tuners together "dynoflash, vishnu, works" and have each of them have their go with the same evo in the same garage on the same dyno. Maybe even have the same driver run the car at the track all in the same day "thats pushing it" but the 3 tuners can definitely have their go on the same car the same day.
Old May 20, 2004 | 02:26 PM
  #164
silverEVO8's Avatar
If I had to do everything over again, I'd take my stock car to the dyno, any dyno, and get some good baseline information as to where the car is in stock form.
Only then, I'd start doing mods. Remember all these cars are different. There are stock EVOs that make over 300 whp (just look at their ETs and Traps speeds). There are others that barely put down 190 whp .....
If your particular EVO is a knock prone car or has other issues that prevent it from making good power right out of the box, it might be better to try and get the car up to snuff. Maybe one could take it to and make them replace or correct the engine problems that show from the dyno sheets including, fuel & ignition maps and timing pull.....
Only if my car was a good running, strong EVO right out of the box, would I then get some mods. Personally, I'd not get any off-the-shelf solution that may or may not work well with my particular car, of course, YMMV, etc.
My plan if all else is right, would be to get some sort of user tuneable piggy back or stand alone and then, go back to the dyno and have a good, competent tuner adjust the device to get the best power safely out of the motor.
Just my $.02
Manuel
Old May 21, 2004 | 01:10 AM
  #165
TYRONEBIGGUM's Avatar
Manuel
really so do you want to explain to me how some evos came out of the factory making almost 70 more crank hp than advertised? 300whp is about 340 crank hp there is no way in hell any evos came with that much crank hp
