4g63 N stroker kit
Old Jul 21, 2013 | 07:19 AM
6466evo's Avatar
4g63 N stroker kit
im new to this forum...little help in deciding stroker kit using 4g63...im intrested to forge my motor with using 4g63 block...what options do i have ...2.2 would be ideal but not sure if i can use 4g63 block for that...?ideas are welcome
Old Jul 21, 2013 | 11:18 AM
6466evo's Avatar
anyone with ideas
Old Jul 21, 2013 | 11:58 AM
misterevo8's Avatar
it really depends on your build bro. what turbo will you be running? run a 2.3 stroker with a fp black along with supporting mods.
Old Jul 21, 2013 | 12:17 PM
CoachG's Avatar
If 2.2l is ideal for what you have planned (and you need to stay with the 4g63 block), look into a 94mm crank from any one of the major manufacturers (i.e. Manly, Cosworth, Jun, Tomei, Toda, Winberg, GSC, K1, etc.).
6466evo's Avatar
will be running 6466 turbo 1/4 mile...which setup is required to build 2.3
Old Jul 21, 2013 | 04:43 PM
allevolution's Avatar
Theres a million and one threads on here about motor options.
Try seraching
Old Jul 21, 2013 | 05:11 PM
6466evo's Avatar
Originally Posted by CoachG
If 2.2l is ideas for what you have planned (and you need to stay with the 4g63 block), look into a 94mm crank from any one of the major manufacturers (i.e. Manly, Cosworth, Jun, Tomei, Toda, Winberg, GSC, K1, etc.).
what about eagle 94mm crank can that not handle 9500 rpm and 6466 high horse power?
Old Jul 21, 2013 | 05:43 PM
Why the hell would you build a 2.3 for 1/4 mile?
Sounds like you need to do alot of researching.
1/4 mile racing is high rpm maximum power.
Look into one of these two options:
2.0= 4g63 block, 88mm crank, 150mm rods, standard pistons
2.1- 4g64 block, 88mm crank, 150mm rods, w.e 4g64 spec pistons are
Old Jul 22, 2013 | 01:19 AM
6466evo's Avatar
im not looking into 2.3 .....im looking at 2.2 .which can be rev'd for 1/4mile
crazy_ugly_coyo
15
Sep 29, 2015 07:53 PM
bsh
Jun 6, 2013 12:49 AM
1HIPCAT
16
Jan 28, 2007 08:02 PM
EvoIX7
13
Jul 27, 2006 06:35 AM
stvbreal
19
Apr 23, 2003 09:45 AM
