Bushur Racing 2.3L short block
Old Jun 24, 2014 | 10:28 PM
ms32evoixmr's Avatar
I just have a quick question. I currently have an AMS 2.3L stroker with stock heads in my evo ix mr. Just learned that my motor has crank walk. Now my main question is would a BR 2.3L 4g63 short block bolt right into my evo ix mr stock head without any mod to it?
Old Jun 24, 2014 | 10:40 PM
Faisalm's Avatar
Yes.
Old Jun 25, 2014 | 04:42 AM
slowsrt4:('s Avatar
What he said ^
Old Jun 25, 2014 | 05:56 AM
evolve_VIII's Avatar
From your other thread, are you sure you have crank walk? Can you post a video of it moving back and forth?
It will work, depending on the block, you will have to drill the oil port in the back of the block for the MIVEC oil feed line. If you tell buschur it is for an evo 9, he should know what to do.
Old Jun 25, 2014 | 06:53 AM
Unfortunately, I don't have a video of the crank walk. But the shop's mechanic is certain that it is crank walk due to .25 inch free play. It hasn't destroyed the crank sensor, but they are not even going to touch the car unless a new short block is in the car. So at this moment, I am looking at A Bushur short block. I'll make sure to let them know that it is for an evo ix.
Old Jun 25, 2014 | 07:43 AM
240Z TwinTurbo's Avatar
If the crank has 0.25" end play then I don't see how it would not damage the crank sensor. If you look at the picture below the trigger wheel spins between the gap in this sensor.
Old Jun 25, 2014 | 07:47 AM
I still dont trust that information. You should go see it for yourself and get a video of it. A quarter inch of crank walk will destroy the sensor and there will be tons of metal in the oil.
Just because you are burning oil does not mean you have crank walk. That could be larger ring gaps (due to a built motor) and/or leaking valve seals.
I highly recommend you DO NOT buy a short block based on this information. You are wasting a lot of money.
Bring the car somewhere else if they are not wanting to touch the car without a new engine installed. To me that is bullshi*.
Just trying to help you out before you fork over 5k for a new motor and parts for no reason.
Old Jun 25, 2014 | 07:51 AM
Faisalm's Avatar
^^ +1 This
^^^ +1.02 And this!
Is this a reputable shop? Have they done work on Evos before?
Old Jun 25, 2014 | 08:27 AM
Originally Posted by Faisalm
^^ +1 This
^^^ +1.02 And this!
Yeah, this shop is well known for Evo's and Gtr's. Their reputation is undisputed. Has the fastest evo in California.
Old Jun 25, 2014 | 08:31 AM
Thank you for your input. I'm actually going to head over to the shop and have them show me the free play before I do anything else. They are a very well known evo and gtr's tunning shop here in the Bay Area. So I have full confidence in them. But I would still like to see it for myself before I fork out the funds for a new short block, as you recommended. Thank you again. I'll update you guys on what I find out.
Old Jun 25, 2014 | 08:55 AM
Also, just show up and request to see it. I would not call ahead.
Please keep up posted and post a video of it when you go. I am curious to see this magical .25" of walk without damaging anything.
Also, while you are there, have them drain the oil and check for metal flakes. Thats another sign of bearing material in the oil. They could also mean .025mm of walk. This is within spec. The spec is 0.05-0.25mm. Need clarification of this and have them use a dial indicator.
Old Jun 25, 2014 | 09:57 AM
Faisalm's Avatar
If they haven't drained the oil yet to confirm their analysis, then I don't know what to say....
Old Jun 25, 2014 | 03:48 PM
mitsubeastlee's Avatar
fastest? fftec?
Old Jun 25, 2014 | 04:10 PM
oscarquinones's Avatar
they have the best reputation for evo parts
OneCrzyEvo21
Jun 15, 2016 04:53 PM
evole97
May 12, 2015 05:42 AM
haseeb
Nov 17, 2007 11:42 AM
Forrest Gump 9
Oct 20, 2007 01:27 PM
Buksh
33
Jun 30, 2007 04:36 AM
