Using factory fuel feed for return
Old Jul 10, 2014 | 04:48 PM
nismo3183's Avatar
I have been waiting on a fuel system that has been on back order for months! (they will remain nameless...this thread is about other issues) and have decided that I need to come up with another fuel solution.
In the meantime, I will be installing a Buschur double pumper utilizing -6 from each pump joining to -8 to the rail. I also am using a fuelab pressure regulator and fic rail with 2150 inj.
My question is can I use the factory feed as a return without disturbing the siphon effect? I am not familiar how the siphon system works on Evo's so I'm asking for some help with this. Am I going to have any other fueling issues if I change my fuel line diameter? I have seen this done plenty of times but I am not sure if I have to alter anything else in order to use these diameter lines.
btw this is for a 2.2 built block and head setup with a 6466 in kill mode on both e85 and 93.
Old Jul 11, 2014 | 04:52 PM
nismo3183's Avatar
100 views and nobody can help me out???
Old Jul 12, 2014 | 01:59 AM
Jsiebert's Avatar
I use the feed as return and as far as I can tell I havent had an issue yet.
Old Jul 12, 2014 | 03:30 PM
nismo3183's Avatar
What about any issues with fuel getting stuck on one side of the tank?
Old Jul 12, 2014 | 04:23 PM
420a-t's Avatar
How are you connecting it to the fuel pump assembly?
Old Jul 12, 2014 | 05:37 PM
evo8426's Avatar
The issue with fuel being stuck on one side is when you start modifying the siphon tube. You could run a -10 line and not have any problem.
Old Jul 13, 2014 | 06:38 PM
nismo3183's Avatar
I honestly have not thought about it as of yet. I was just concerned with increasing the diameter of the line. Do you have any suggestions for how I can connect a larger return line?
Old Jul 20, 2014 | 06:22 PM
mrfred's Avatar
i'll just clarify that the siphon has nothing to do with the return line.
Old Apr 13, 2015 | 06:28 PM
evojoe90's Avatar
bump! anymore info on this?
Old Apr 14, 2015 | 05:40 AM
Ted B's Avatar
The siphon effect is created by a white plastic 'T' tube that is located in the fuel pump assembly. It is plainly visible when the pump assembly is lifted from the tank. Fuel from the return line flows through the straight part of the 'T', which creates a suction effect on the 90 degree tube. That suction draws fuel from the right side of the fuel tank into the left. So long as you connect your return line to the same fitting on the pump assembly housing, you have nothing to worry about.
Old Jul 29, 2015 | 06:45 AM
DSMolition's Avatar
I have been thinking about this also. I ran a -6 an line to my rail fromt the stock pump feed fitting and want to use the stock 5/16 line that im not using anymore for my return. so i would go -6 return from the regulator to the 5/16th hard line.
Not sure how to connect it on the hanger side yet where it necks down to 1/4 for the stock return fitting on the top of the hanger to make it worth it.
Any ideas?
Seidelly
May 9, 2016 11:15 AM
letsgetthisdone
Apr 25, 2016 06:39 PM
Seidelly
Apr 4, 2016 10:26 AM
05evoGSR
14
Apr 16, 2011 06:29 PM
David Buschur
61
Jul 28, 2008 07:20 PM
