Wiseco ring gap
Old May 27, 2015 | 07:41 AM
WikdEvo's Avatar
Is the above ring gap correct? It would see that it is a lot tighter than the rest of the calculations I've seen. Is it not .020in and .025in?
Old May 27, 2015 | 12:37 PM
LetsGetThisDone's Avatar
LR2.4 is in a 4g64 block, larger bore than 4g63, therefore, larger ring gap..
Old May 27, 2015 | 12:55 PM
WikdEvo's Avatar
That doesn't make any sense to me. The gap is measured between both ends of the ring... Not the actual diameter of the ring.
Old May 27, 2015 | 03:24 PM
Right, but a larger cylinder bore requires a larger ring end gap. You set the gap higher on an 87mm bore than you do an 85.5mm bore..
cerevo
12
Sep 9, 2016 03:45 AM
Andrewkbmx
Mar 5, 2015 09:02 AM
jameswwt
29
Dec 8, 2014 07:49 AM
Schia89
Aug 13, 2014 08:45 PM
ezzey
Dec 6, 2012 09:58 PM
