Review: FP 71HTA
Old Feb 27, 2016 | 01:46 PM
  #166
revhappy's Avatar
Originally Posted by kaj
Power isn't completely dependent on torque. Max power is as much as you can make and you can keep the torque anywhere you need.
Where do you live that cams are $1000+?
I'm counting the costs of beehive springs and retainers as well as the labor to put S2 cams in.
Yeah, I know if you can keep the torque at high rpms you can make good power, but I'm just curious how much torque you can keep that high in the rpm range if you limit it to 385 and try to keep the powerband wide on the HTA 71. Basically, if the S2 cams are just going push the whole torque curve up then I'd just stick with HKS 264s on E85. I know you can tune to prevent the torque from being too high to some extent, but just haven't seen any examples with the HTA 71, aggressive cams and E85 with torque at 400 or below.
Old Feb 27, 2016 | 05:52 PM
  #167
RazorLab's Avatar
You can do the math and know exactly what is possible horsepower wise per amount of torque at any given rpm: hp = rpm times torque divided by 5252.
What that means in relation to this is that just because you limit torque down low doesn't mean you sacrifice horsepower up top.
What you do sacrifice is power under the curve.
Old Feb 27, 2016 | 07:00 PM
  #168
tsitalon1's Avatar
Originally Posted by awhit17
I just went back and checked my dyno graph, i hit 300wtq at ~3300-3400 rpm on 93 with the 71HTA. Stock block.
Hopefully that helps?
Thank you, this falls in line with what I would expect and hope for.
Assuming you have a IX, my results should be similar...hopefully my Kelfords won't push me to too far to the right.
Now the decision...do I use my stock ix turbo housing with 40k miles, or my hta green housing?
Old Feb 27, 2016 | 07:55 PM
  #169
awhit17's Avatar
Yes I have a IX, with Tomei 270 cams as well. I made 402whp on 93 @ 23psi. Mustang dyno so not VD.
It's a great turbo! You should use your stock IX housing since the 71HTA uses the stock turbine
Old Mar 1, 2016 | 01:05 PM
  #170
revhappy's Avatar
Just catching up. Here's mine
Can you give a list of your mods?
Old Mar 8, 2016 | 08:48 AM
  #171
ViciousLSD's Avatar
Evo9, s1 cams, stockish air box, walbro 255, 1100 cpm injectors, megan/3"ID exhaust, upgraded IC hoses... thats it i think
Old Mar 8, 2016 | 08:07 PM
  #172
RazorLab's Avatar
Ya'll.
KFC went to the strip today. Before on 93 he trapped 114mph.
Today he trapped 119 as a high and did a 11.92@118 with a 1.861 60ft as his best on E85.
Full weight SSL sunroof and leather car with spare and tools out.
Changes from above where a Wally 450 pump (to get fueling back inline) and AFPR.
Here is the log from his drag run. Sharing because I feel people don't share these types of logs enough.
http://datazap.me/u/razorlab/scott-h...17-19-21-36-56
Old Mar 10, 2016 | 03:14 PM
  #173
tsitalon1's Avatar
Ok, Offically downgrading (or is it upgrading ) to the 71hta from the HTA green.
Ordered - Excited
Old Mar 10, 2016 | 03:34 PM
  #174
kaj's Avatar
kaj
Ordered - Excited
I just sold mine with just a few hundred miles on it. You coulda saved some cash LOL. I'm moving up to the new HTZ Green.
For what it's worth, it's not because I'm unhappy with the white. The white is the best turbo I've ever owned, but my car is road race focused and the Green won't have to work as hard.
If I were daily driving my car, with occasional track day use, no way would I have gotten rid of my white.
Old Mar 10, 2016 | 03:44 PM
  #175
tsitalon1's Avatar
Yeah I thought about asking a few of you guys that are upgrading if you wanted to part with yours....oh well...No worries.
Yeah, I'm 100% DD, and I'm currently at 400whp 360wtq on the green with 93, from the looks of your guy's graphs, I should have about the same power but much better spool and transient response.
At least that's the hope, if not it will be for sale soon
Old Mar 10, 2016 | 03:56 PM
  #176
Erik@MIL.SPEC's Avatar
How "bad" is the transient response? You have a Green on there...it's not like it's a SS Black
Old Mar 10, 2016 | 04:21 PM
  #177
kaj's Avatar
kaj
Maybe. I was at 365whp on 91oct. My mods list is super modest. Better fuel and a decent cam should make a decent amount more. I think you should be really close to that, if not spot on. Oh, and my tunes are track-safe.. so even i could have made a bit more.
Old Mar 10, 2016 | 04:26 PM
  #178
tsitalon1's Avatar
Peak torque is currently around 4500rpm...should be around 3500-3700 best I can tell on a 71hta.
Old Mar 10, 2016 | 05:43 PM
  #179
kaj's Avatar
kaj
That doesn't sound right at all. Unless you were intentionally ramping up the torque to save your engine internals, or something?
Either way, that won't affect transient response. Spool and response are different.
Old Mar 10, 2016 | 05:54 PM
  #180
tsitalon1's Avatar
Most hta green plots I've seen on pump gas cross 300wtq around 4k and peak torque around 4.5k...I don't think I'm that far off.
Mivec maxed at 28.8 during spool.
Idk...maybe my kelfords are hurting spool a bit...but shouldn't be too much.
Excited to see my plots with the 71hta.
