Review: FP 71HTA
Old Mar 10, 2016 | 07:21 PM
  #181
kaj's Avatar
kaj
Originally Posted by tsitalon1
Most hta green plots I've seen on pump gas cross 300wtq around 4k and peak torque around 4.5k...I don't think I'm that far off.
Mivec maxed at 28.8 during spool.
Idk...maybe my kelfords are hurting spool a bit...but shouldn't be too much.
Excited to see my plots with the 71hta.
Nevermind, i read your post in a hurry. My mistake.
My White was at 300ftlbs at 3600-3800, so 4k on the Green sounds right. I hear about 200rpm difference in spool. That's fine with me and expected. I also reached peak torque (370ftlbs) around 5k. Sounds to me like the Green and S1 cams will work just great for my application.
Old Mar 10, 2016 | 07:29 PM
  #182
tsitalon1's Avatar
I think you should of hit peak torque sooner than that, if I'm not mistaken I've seen others cross 300wtq at 3300-3400 on 93..but your using 91 right?
I think the 71hta should hit peak torque around 3800 with the FAP cover.
Old Mar 10, 2016 | 07:36 PM
  #183
awhit17's Avatar
I made peak tq @3900 with my 71HTA, pump gas.
However, this was where the turbo overshot target boost by like 1psi, so if you flatten out the spike peak tq seems to be right around 3700-3800
Old Mar 10, 2016 | 07:46 PM
  #184
kaj's Avatar
kaj
91 sucktane, yeah LOL. It's all my tuner could do with timing with our sucky gas here. If i had cams, IC piping, etc, maybe things would be different, better gas for sure. I have 0 complaints, though. The thing was a beast. Still the best turbo for the street, IMO.
Old Mar 10, 2016 | 07:56 PM
  #185
tsitalon1's Avatar
This is exactly what I'm hoping for
And maybe since I have 4.11FD, I may be able to load up sooner
I would imagine the response at 2500 would be considerably better than my hta green.
Old Mar 10, 2016 | 08:06 PM
  #186
kaj's Avatar
kaj
Yeah, the 4.11s will take longer to accelerate, so you will reach torque earlier in your log. But what in heck do you need response at 2500rpm for?
Old Mar 10, 2016 | 08:15 PM
  #187
tsitalon1's Avatar
Not that I need it, but it would be nice
Old Mar 10, 2016 | 08:26 PM
  #188
awhit17's Avatar
Here is my graph, actually seeing it may help you more
Cliffs: Stock Block 9, Pump 93, Mustang Dyno, 24psi spike to 23psi out the top
Untitled by Alex Whitacre, on Flickr
Old Mar 10, 2016 | 08:27 PM
  #189
kaj's Avatar
kaj
I know, just giving you a hard time.
I started my logs at 2500RPM and never ran the car at the track at low RPM.. so i'm not sure how it did. The boost curve on the logs is pretty nice, though.
It's SERIOUSLY a fun turbo.
Old Mar 10, 2016 | 08:29 PM
  #190
kaj's Avatar
kaj
on Flickr
Nice! Man, i hate 91. LOL.
Old Apr 3, 2016 | 03:10 PM
  #191
tsitalon1's Avatar
Finally got mine..downgraded from a green...see here:
https://www.evolutionm.net/forums/ev...l#post11598517
Old Apr 3, 2016 | 07:27 PM
  #192
kaj's Avatar
kaj
Too funny: I still have a brand new HTA71 in the garage, but upgraded to the HTZ Green.
Old Oct 17, 2016 | 12:23 AM
  #193
alexc's Avatar
debating on getting the 84mm AFP cover.... sounds like it would hurt spool and low end TQ a bit but help up top and prevent any potential surge issues.
How many of you have the stock appearing cover?
Old Oct 17, 2016 | 07:43 AM
  #194
kaj's Avatar
kaj
I used the stock cover and had 0 problems on my 2.0L.
Old Oct 17, 2016 | 08:54 AM
  #195
ReaperX's Avatar
FYI FP is only selling them with the 84mm FAP Covers. If you have cams it will surge on the stock appearing cover depending on which cams you have. Larger cams have more issues than milder cams. If you do pick one up and are hell bent running the standard inlet I have a standard cover I'd let go for cheap.
